Old 03-22-2013, 08:05 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
About to call Bravo Sierra
Has anyone here had any luck adjusting their Hand/E brake by driving in reverse and braking, or hard braking?
I have tried this a couple times, no difference, at least none that I have noticed. On a Toyota forum they say you really have to slam on the brakes to get them to self adjust.
NEexpat is offline   Reply With Quote
Old 03-22-2013, 09:12 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
never heard of this
Old 03-23-2013, 02:54 AM   #3
bronsin
bronsin's Avatar
As a former car mechanic I saw a lot of self adjusting brakes that didnt work as advertised.
Old 03-23-2013, 03:12 AM   #4
2005rs
Drives: 2005 Echo Rs
The adjusters in the rear drums adjust shoe clearance, not ebrake cable tension
2005rs is offline   Reply With Quote
Old 03-23-2013, 08:27 AM   #5
bronsin
bronsin's Avatar
Right.
But my point was you REALLY want to hand adjust your rear brakes at the wheel or a least check them once a year or so.
Old 03-23-2013, 08:47 PM   #6
nookandcrannycar
Right.
I imagine this is why (when I took my car in last year re the noise the brakes were making) they cleaned out all the brake dust AND adjusted the cable (tight enough to pull past no more than one click when the car was ready). Thirty some odd dollars total for both.
Old 05-30-2013, 10:51 PM   #7
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Let the car roll down a slight decline and depress the brake pedal quite hard....do this a couple of times....that is how it is "suppose" to assist adjusting the rear drum brakes.As the folks said above,it is much better to adjust with the drum off. Don't forget the e-brake handle has an adjustment also....you have to remove the plastic around the lever to gain access to the nut.
frog13 is offline   Reply With Quote
Quad-State Roll Call? lol Zefoxe NY / NJ/ CT / PA 35 10-09-2012 11:46 AM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
Castle Bravo - plasma beauty GeneW Off-topic / Other Cars / Everything else Discussions 6 04-18-2009 09:51 AM
I am going to call Toyota FEINT General Yaris / Vitz Discussion 4 03-25-2009 08:38 PM
