Old 05-30-2013, 08:06 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Making a engine wiring harness
Hey guys, I would like to purchase a aem EMS standalone and Im planning to make a fresh new harness for it.
There are some OEM sensors that I will keep to run the engine, by exemple;
-Crank position sensor
-Cam position sensor
-VVTI solenoid
-PWM on the TB
-TPS on the TB
I have all the sensors, all I need are 2 pieces;
The plastic clip that hook up directly to those sensors and the little metal connector that crimp to your wire and slip into the plastic connector.
I don't want any solder, I want a fresh new harness just like a OEM one.
Where can I find those connectors?
Here is a nice website I found but it doesnt say much about the connectors and they mostly look all the same...
http://www.automotivewiringsystems.c...6-products.htm
maxthehax is offline   Reply With Quote
Old 05-30-2013, 08:19 PM   #2
Are you looking specifically for the connectors for each of the sensors that you listed? If so, I believe that I have all of them on hand.
Old 05-30-2013, 08:44 PM   #3
maxthehax
maxthehax's Avatar
Yes, that should be all. I dont have my notes with me...
Others gonna be AEM, so no need for them;
-water temp
-MAP
If I forget some I will post them later!
Thats a blast you have it all...
What about the metal pins that I need to go into the connectors?? I guess I will need special crimper tool.
Thanks!
Also, I have a echo, so my TB is a drive by cable. Not the electronics one
Old 05-30-2013, 09:20 PM   #4
Others gonna be AEM;
-water temp
-MAP
What about the metal pins that I need to go into the connectors?? I guess I will need special crimper.
Thanks!
What I have are the actual OEM Yaris connectors with the OEM wires (so you would need to solder those wires to you EMS harness. The connector shells would run you about $10 each from Toyota and even they would supply the pins with a piece of wire already attached (for about $15 per pin). The reason for them being pre-crimped is that each pin type requires a completely different crimper (which are about $200 each from Sumitomo).
The TPS connector is different. The Toyota part number for the shell is: 90980-11261
The Idle Air Control connector (what you called the PWM) shell is: 90980-11145
The Crank, Cam, and OCV (VVTI) are the same for the Yaris and Echo.
Old 05-30-2013, 09:26 PM   #5
maxthehax
maxthehax's Avatar
Cool thanks, I understand now what the toyota guy showed me (little wires already crimped)
I am currently working a bit on my yaris engine I have on a stand. I already have most of the connectors with butted wires. So that mean I could buy the piece of wire already crimped to make my connection. That require removing the old wires from each connectors, is that easy to do?
Old 05-30-2013, 09:56 PM   #6
Some of the pins are easy to remove and some are a real pain without a special pin extraction tool for that particular pin type.
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
YARIS Wiring Harness for Sale Lowfront Items for Sale by private party 13 10-11-2006 03:02 PM
