Old 05-29-2013, 03:09 AM   #1
jRoss
Drives: 2010 5spd sedan
Help! High coolant temp light! (I think) ctscott!
Sometimes when I shift kinda hard into either 2nd or 3rd gear, mostly only when I'm turning, I believe my high coolant temp light comes on. At least I think that's what it looks like, it's orange, two humps with a pole in the middle? I don't think my radiator fan is coming on! I just drove to Chicago and back so that may have done it. I don't think the car is actually overheating because the light doesn't stay on, correct? Kinda weird to me that it only happens when shifting and turning. Any insight would be great, I'd like to get this fixed ASAP cause I need my car all the time.
jRoss is offline   Reply With Quote
Old 05-29-2013, 03:47 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Sounds like tire pressure light as u describe it. Try adding air into the tires first
-Derrick-
Old 05-29-2013, 04:06 AM   #3
jRoss
No it's def not tire pressure, that stays on all the time cause my rims don't have sensors. It's on the left side of the cluster close to trac off.
Old 05-29-2013, 05:31 AM   #4
jRoss
Used someone else's owners manual, low wiper fluid haha sorry just got freaked out on the way home from work
Old 05-29-2013, 11:02 AM   #5
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
That freaked me out too the first time I saw it while shifting gears - but I knew it wasn't the coolant light.
DebbyM46227 is offline   Reply With Quote
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
