Old 06-05-2013, 12:21 PM   #1
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
zage turbo in and running but engine stalls at idle! what could it be?!
Zage kit is in, managed to get it tuned however, still having a bit of an issue with the engine once it warms up and started driving around and when the vehicle is stopped say at a red light, rpms idle at about 700 and then it just drops and the engine stalls.
I'm running with AEM FIC and all numbers are within normal operating spec. 1ZZ injectors running at about 85%
I've read on MI and YW that others have had the same similar problem but haven't found a possible solution for those using a turbo kit?
I've even tried adjust the screw that's covered in epoxy on the throttle body which controls the position of the TB but with no luck.
Any input is greatly appreciated!
DKN-YARIS is offline   Reply With Quote
