Old 03-01-2007, 07:26 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Side Marker Bulb Swap DIY How-To [pics]
Yes, its true.. your side markers on your Yaris Liftback are a SEALED housing.
Here's how to swap in any color bulb or LED replacement.
Step one, remove the side marker from the fender.
Grab it, and slide it foward, while pulling the rear out towards you, away from the fender. Side marker will pop right out. This step is also outlined in your owners manual.. go figure.
Tools needed.
New hack saw blade - used to cut housing. Do not use a Dremel or other electric device, as you will cut to far, and ruin your housing.
Electrical tape or Hot Glue Gun, or both - used to seal the two halfs back together.
Sand paper - used to clean up halfs after being cut, before sealing up.
Time to cut.
Cut where shown in picture.. about the middle of the housing. Start cutting slowly, as you are only cutting through maybe 1/8" of the plastic housing.
You will know when you have cut far enough. You will feel increased resistance, as then you will be trying to cut the metal of the bulb socket.
Housing seperated.
Rough edges from the cutting, these will be sanded a bit in the next step.
Sanded both halfs.
Doing this to clean it up a bit, and to give whatever glue/sealer you choose a "bite" into the plastic.
Insert your replacement bulb of choice. Mine happends to be a 194 HiLEDS led.
This next step is all your choice!
You can attach the two halfs by lightly tacking the two together with hot glue, then once cool, tightly wrap with electrical tape.
There will be MANY different ways owners will use to seal theirs up, simple electrical tape, tightly wound a good 10 times or so is more then enough though. The two halfs become a strong connection again, and will not allow water or moisture to get inside... also the easiest route.
Enjoy yet another Chris07LB DIY!
Old 03-01-2007, 07:38 PM   #2
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
Thank You, another job well done
My Car
My Garage
BokChoi is offline   Reply With Quote
Old 03-01-2007, 07:55 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Very nice Chris, this is literally a hack job
I was thinking of doing this myself, but didn't know how far to cut the housing.
Chalk it up to another Chris07LB DIY
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 03-01-2007, 07:56 PM   #4
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
I dont know about white but....red might be cool to go with what WILL be my white/black/red theme.....and also depends on if anything other than amber is legal in VA.
jdubau55 is offline   Reply With Quote
Old 03-01-2007, 08:03 PM   #5
Chris07LB
Chris07LB's Avatar
Flashing RED isnt in ANY state...
Old 03-01-2007, 08:44 PM   #6
So just to confirm, these 194 LEDs are just the same as you used in the parking lights up front, right?
Old 03-01-2007, 09:22 PM   #7
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
and the map light and the trunk, if not mistaking
YamilR is offline   Reply With Quote
Old 03-01-2007, 09:34 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
also the rear plate lamp
Old 03-02-2007, 06:45 PM   #9
Chris07LB
Chris07LB's Avatar
Correct, except for the trunk.. Liftbacks need a festoon LED replacement.
Old 03-02-2007, 07:09 PM   #10
Jfoofoo
Jfoofoo's Avatar
Drives: 07 Yaris HB Meteorite Metallic
is the white sidemarker legal in NJ? what is the reason you switch to orange?
ps. Thanks for such great DIY.
Jfoofoo is offline   Reply With Quote
Old 03-03-2007, 08:39 PM   #11
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I have to ask, now that you have the new bulbs in, how do you like the look? They are so bright in the photos that it's hard to tell what they really look like.
Galavoxx is offline   Reply With Quote
Old 03-03-2007, 10:03 PM   #12
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
make a videooooooooo :)
Old 03-04-2007, 07:57 PM   #13
Chris07LB
Chris07LB's Avatar
Didnt... only because everything else, as seen in the pic's, is amber/orange... I dont plan on changing so these are being replaced with HiLEDS 194 amber led's.
Old 03-01-2007, 10:59 PM   #14
ChinoCharles
Drives: LB
How many DIY's does it take to get to the moderator-status center of a Yarisworld pop?
The world may never know.
Chris, great DIY... again.
Old 03-02-2007, 03:24 AM   #15
hasher22
Look mum no stars!!
hasher22's Avatar
oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooo :)
Old 03-02-2007, 03:33 AM   #16
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I guess I'll be working my way to swapping out the lights after i get another set of HiLEDs bulbs. Thanks a lot Chris for finding yet another way to modify the Yaris.
Old 03-02-2007, 09:48 AM   #17
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Chris:
We are not worthy (ALA Wayne's World style)
TrancosRt is offline   Reply With Quote
Old 03-02-2007, 10:00 AM   #18
uncleyaris
you da MAN!!
side marker lights yrsdrgn Cosmetic Modifications (Exterior/Interior) 154 07-10-2009 02:55 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
