Old 06-17-2013, 10:45 PM   #1
GrayFox
Drives: 2009 5 Door YRS
Help.. Confused with tomtom eclipse install.
Hi guys, my Yaris is a 2009 Hatchback. It came with only a standard double din head unit. So I thought I would upgrade to the Tomtom/eclipse unit as I found a decent deal on ebay recently. Now here is my problem. I have connected all the wiring and it works, no problems with functionality. However once installed the unit sticks out more than what I expected, and more than what I see on all other Yaris on here. So here are the pictures to explain.. I'm starting to think this head unit was not designed for my model of Yaris.. Would really appreciate your ideas.
GrayFox is offline   Reply With Quote
Old 06-18-2013, 05:33 AM   #2
Toyota actually makes a different set of the sheetmetal side brackets, specifically for that radio (when it is part of the TNS400 kit). The part number for the brackets is: PZ415-B0330-60
The difference with the kit brackets is the placement of the holes. You can drill a second set to push the radio in further.
Old 06-18-2013, 10:12 AM   #3
GrayFox
Thank you. Do u happen to have a picture of that one so I can try to replicate it?
Old 06-18-2013, 10:57 AM   #4
It looks like I do not, but these images from the TNS400 installation manual should help, as they show which screw holes in the AVN2210P are used with the brackets:
Old 06-18-2013, 03:19 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If you can wait until this weekend, I'm going to be pulling mine out to wire up the AUX input. I can take a few pictures then.
In addition, I'll see about posting a solution for a DIY version of the AUX105 stereo/MP3 cable since the OEM one doesn't seem to be available anymore.
Old 06-18-2013, 07:10 PM   #6
seth_man
seth_man's Avatar
Drives: 08 Liftback
what I did when I installed mine is just used 2 holes on each side, and modified 1 hole slightly for better alignment.
here you can see the lower hole was modified a little bit to get the bolt to sit right, took like 20 minutes to get it in the right spot
seth_man is offline   Reply With Quote
Old 06-18-2013, 09:57 PM   #7
GrayFox
Thanks for all the pictures and help. Looks like I'm also going to need to speak to Mr Toyota to order the correct 2din size trim pieace :)
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
