![]() Drives: 2009 Yaris Join Date: Mar 2011
iDatalink Maestro
Just picked up an 09 Yaris S 4 door sedan. Considering changing the head unit out with a iDatalink Maestro compatible unit and wondering if there is any data available that would be worth buying the Maestro stuff during install. Thanks!
All my research showed conflicting info on this so I ended up picking up a new head unit with install kit/wiring from sonic electronics. Ordered the backup camera from ebay. Any tips on mounting a universal back up camera?
#3 | |
For example: https://www.aliexpress.com/item/BigB...ceBeautifyAB=0 I wouldn't count on it being ultra high resolution. And, I think I would go for a hardwired one, not the transmitter/receiver type. Though that may require running more wiring. There are many choices. I just used search terms, "2009 Toyota Yaris Sedan Backup Camera".
Thanks. I saw another post you had after I purchased a universal but now I'm thinking this might be a good route. Seeing a lot of different designs too such as:
https://www.ebay.com/itm/Auto-Car-Re...gAAOSwTM5YxXC2 |
#5 | |
Found the right one and installed it recently. Very nice to pop out the old license plate light and pop this one in. Highly recommended!
Everything is installed now except I havent connected the green parking brake wire. Can't seem to find detailed info on what it does and if it's better to leave disconnected or how to connect it. In the meantime, installed heated seats. Car's really coming along nicely. |
#7 | |
Never heard of a parking brake wire related to the backup cameras. Just the reverse lights to trigger the camera on.
I tried awhile back on the pics and kept getting an error that the file size was too big. Was trying to do it on my iPhone.
The green wire isn't directly related to the backup camera but some other function, I'm guessing a video function of the head unit. |
#9 | |
Yeah, I bet enables video playback when the car is stationary, aka parking brake is set.
| Maestro RR Compatible? | Sdelliott | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 07-15-2017 11:29 AM |
