Old 07-30-2013, 08:03 PM   #1
3cyltrbo
Exclamation Problem with DC Sports header
Its hard to see in the photos, but because of the location of the O2 sensor bung on the DC sports header, the backside of one of the bolts attaching the header to the downpipe is going to contact the O2 Sensor.
I've attached two photos.
1 is unedited (to show the original)
1 is edited with Green and Red circles to show the following.
The bolt holding the downpipe to the header (circled green) is almost fully seated and not hitting anything.
The other bolt (circled red) is just sitting there in its hole, but if I thread it even 2 or 3 turns its going to be pushing on the O2 sensor (not good)
If I tighten the bolt (circled Red) all the way like its supposed to be, it will certainly make a huge impact into the O2 sensor
Anyone else run into this?
After struggling for quite sometime to get the old header off / replace the factory header hardware with the ARP stuff (also from Microimage) I'm kinda at a loss as to how to proceed.
Help >>>>>>>>>>>>>>>>>>>>>
Will
3cyltrbo is offline   Reply With Quote
Old 07-30-2013, 08:14 PM   #2
There was someone else either on here or on the MI forum that had the same issue. If I remember correctly the solution was sending it back for a replacement.
Old 07-30-2013, 10:31 PM   #3
3cyltrbo
Thanks CTScott
Anyone here one of the people who had a prob?
Will
Old 07-31-2013, 12:11 AM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Check this thread. http://www.yarisworld.com/forums/sho...header+problem
His issue was not putting the gasket on. Looks like yours is on, but did you check?
Old 07-31-2013, 12:19 AM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Make sure you're not using the bolts from the muffler.
Old 07-31-2013, 01:10 AM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yeah, send it back and get a Weapon R.
They have no fitment issues.
Old 07-31-2013, 01:18 AM   #7
7:34pm
Drives: 07 Yaris
what about if you remove the o2 sensor and flip that one bolt so the head is against it?
7:34pm is offline   Reply With Quote
Old 07-31-2013, 01:38 AM   #8
That looks like the older, defective DC Sports design, where the O2 sensor bung was incorrectly placed. They have corrected that issue.
Old 07-31-2013, 03:28 PM   #9
Altitude
Altitude's Avatar
Garm - Is there any way to identify these before hand? I ask because I just ordered one from you guys and don't want to have to go through the trouble of trying to install it only to find it's defective.
Thanks!
Old 07-31-2013, 04:12 PM   #10
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Thanks!
If you bought it from Garm I doubt you will have a problem. I bought mine from him a couple years ago. Once I put that gasket thing back in, it worked fine.
Old 07-31-2013, 09:07 AM   #11
47_MasoN_47
I had that problem, but for me it was due to forgetting to put that little gasket between the header and the midpipe.
Old 07-31-2013, 09:33 AM   #12
mario98c
mario98c's Avatar
Cut the tip of the bolt and problem fixed! lol
Old 07-31-2013, 11:14 AM   #13
tooter
play every day
tooter's Avatar
While that's a good idea, it could create a lot of problems getting the spring loaded bolt to engage the threads of the flange.
Old 07-31-2013, 11:21 AM   #14
3cyltrbo
X2
Old 07-31-2013, 11:20 AM   #15
3cyltrbo
Yup, I'm sure the Gasket (round donut) is on
I haven't been anywhere near the muffler yet
I would love to but (I'm impatient and I have a show this weekend)
I can't do that with the factory bolt because of the way its flanged
Wish I had known this before I bought it
As above, I am 100% certain that the donut is installed.
I guess the pictures don't do it justice, the O2 sensor is almost rubbing on the flange as is / I'd have to cut almost all the thread off the bolt
Old 07-31-2013, 12:26 PM   #16
Another option would be to weld a new bung in a better location for the O2 sensor and plug the existing hole.
Old 07-31-2013, 12:46 PM   #17
3cyltrbo
Originally Posted by BEEF View Post
I'd go without the header for the show (put the factory one back on) and send it back. The longer you keep it, the harder warranty stuff will be.
I am actually a big fan of the Weapon-R (I has one) and would recommend it. There is also a huge price premium between the two... and I haven't heard of any issues with them.
I've thought of putting the factory one back one, but I've been chomping at the bit to have a header
I paid $250 ish and I find the Weapon R for about $230 ish / not sure why I went DC sports in the first place?
I am totally considering that!, only problem is it would most likely read off just one cylinder (although I think I've read about others that had a similar setup and didn't experience any drawbacks)
Old 07-31-2013, 12:15 PM   #18
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
