![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
Why won''t my airbag light go away?
Hello, my airbig lights won't go away when I turn on my engine. I would like to clear these lights or fix them but don't know how. I've been thinking about taking it to a dealership but they probably want an arm and a leg just to look at it. I'm worried about my safety if these airbags are damaged or won't deploy in an accident.
What can I do? Thanks in advance. ![]() ![]() |
Most likely your spiral cable is the issue and most 2nd generation Yaris are under the recall for said issue. If you want to be sure before knocking on the dealer's door, you can read the codes yourself with just jumping two pins on the OBD port under the dash:
http://www.yarisworld.com/forums/sho...d=1#post557473
| SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! | tylerwatts53 | DIY / Maintenance / Service | 1 | 07-17-2014 08:53 AM |
| Fan Not Spinning Up, Random Airbag Light | drannonb | DIY / Maintenance / Service | 12 | 10-23-2012 03:33 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
