Old 08-05-2013, 06:59 AM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
Less power !!?!
Hello, during these last 3 days i experienced some troubles with my 2009 Yaris.
It is powered by a 2NZ-Fe. Here what i noticed:
- engine On + A/C On = engine vibrating massively as if it is going to shutt donw
- engine On + head lights On = when i apply gas lights become brighter , when i release gas lights become less bright and engine starts vibrating
- less power on the road
- A/C goes Off and On all the way
What i did:
- checked air filter ( replaced new one)
- thought may be poor gas and i filled it with new one
- checked A/C cooling liquide and its fine
What do you suggest???
yarismo is offline   Reply With Quote
Old 08-05-2013, 07:17 AM   #2
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
I would inspect your belts, and possibly the alternator.
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 08-05-2013, 06:19 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+1 for the alternator check.
Old 08-05-2013, 09:37 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Your symptoms sound like it's the battery.
Either weak from not being charged, or just old and ready to be replaced.
How old is your battery?
Old 08-24-2013, 11:44 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
X2 on this ^
Old 08-05-2013, 09:54 PM   #6
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
yep, electrical load issue have battery and alternator testes
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
