Old 08-07-2013, 06:40 PM   #1
hotnoodle
Drives: 2006 Yaris hatchback
changing standard stereo
Hi,
I have purchased a 2006 toyota yaris yrs that comes with steering wheel controls.
however the standard stereo does not have blue tooth, Usb or aux connections.
I was wondering if I purchased another toyota stereo model with all these features will it be compatible with the steering controls.
If anyone could help it would be great. Also would it be an easy change over?
Thanks
hotnoodle is offline   Reply With Quote
Old 08-07-2013, 07:36 PM   #2
As long as the Toyota stereo is one that supports steering wheel controls it will definitely work.
Old 08-07-2013, 07:43 PM   #3
mr_miles
Drives: 2013 Yaris
I'm not entirely sure, and I'm sure a certain CTScott would chime in - Provided the controls would work, I have a factory Toyota stereo out of my 2013 that has bluetooth and USB aux built in I could send to you :) This one, to be exact.
Edit: haha, he beat me to the punch as I was typing this :p
Old 08-07-2013, 08:15 PM   #4
That would definitely be one that would work. With that one you would just need an antenna adapter, since the newer Toyota radios use a different antenna connector than the 2011 and older ones do.
Old 08-07-2013, 08:53 PM   #5
hotnoodle
Hi guys,
The one I was thinking about purchasing was this particular model on the dash of this.
http://www.toyota.com.au/hiace/features/interior
Old 08-08-2013, 05:30 PM   #6
hotnoodle
The model of the stereo is Ft0022a.
I can't upload a picture for some reason.
It should be fairly straight forward right ctscott?
Old 08-08-2013, 06:48 PM   #7
Check the dimensions of it to be sure, but I believe it will fit and be fully compatible, other than needing the antenna adapter.
Old 08-11-2013, 10:14 AM   #8
hotnoodle
Thanks for your help ctscott.
Stereo has been installed. Needed the radio adapter like you said and another harness that plugged into the stereo.
Would you know where I can find a user manual for the Toyota stereo?
Model is Ft0022a.
Old 08-12-2013, 01:16 PM   #9
jcboy
Drives: Sedan 07
There is an aftermarket stereo designed for Toyota's 200mm hole (as compared to the standard 180mm).
No splicing of wires and all, and comes with bluetooth, USB and aux input.
Just a thought if you're looking into replacing your stereo anyway. I am unsure if it's readily available in US shores without going through international shipment/ebay.
edit: you're in Aus so just google this if you will. Kenwood DDX630WBT
http://www.ft86club.com/forums/showthread.php?p=881216
Old 08-12-2013, 02:29 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
Hey when starting a new thread PUT IT IN THE RIGHT SECTION. Not everything belongs in General. Moved.
Old 08-12-2013, 05:31 PM   #11
hotnoodle
Sorry astroboy. I'm new to this so I'll keep that in kind for next time.
Jcboy, I have already bought and installed the Toyota head unit. Just looking for an instruction/user manual as if didn't come with one when I purchased it.
Any help locating will be greatly appreciated!
Old 08-28-2013, 12:10 AM   #12
pardos
Drives: yaris
nowdays most of car stereos support steering control.and the stereo comes with lots of functions . if you bought the special model fitting your car . there is no need to worry about the issues unless the quality. i think the one is great :DVD Radio Special for Toyota Yaris - Navigaiton Digital TV DVB-T you can make a comparison
pardos is offline   Reply With Quote
Replacing the stock stereo in a Yaris 2, #2039; 56k, are you serious? Kar98 In Car Entertainment + Electronics (audio / video / alarm) 6 10-02-2017 04:18 AM
changing alternator ryota DIY / Maintenance / Service 5 04-02-2012 11:20 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 03:41 PM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 01:58 PM
