Old 11-07-2008, 04:11 PM   #1
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
07 or 09 bumpers
since i got some scuffs and a couple of dings in my bumper, i was thinking if i should try and fit the 09 bumpers on my 07, keeping the stock look in mind. i think it should just bolt up with no problem and giving it a fresh look to boot, only thing is are the headlights different with the 09's? they look like they curve a bit on the inside.
staypuft is offline   Reply With Quote
Old 11-07-2008, 04:41 PM   #2
You definitely would need to replace the headlights as well. Sodium_Duck and I took some measurements on his 08 and my 09. All sheet metal is indentical (and hence bumper mounting points), but the jog in the 09 bumper requires the matching jog in the 09 headlight. To replace yours with an 09 you would also need the 09 upper and lower grills, as they are different as well.
Will 4 door liftback bumpers fit the 2 door liftback? 118traut Cosmetic Modifications (Exterior/Interior) 11 02-19-2011 03:38 PM
RS tail lights and bumpers uraz General Yaris / Vitz Discussion 59 04-22-2006 10:20 PM
