Old 11-26-2008, 02:56 AM   #1
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Super Amazing Oil Change DIY
id3379 is offline   Reply With Quote
Old 11-26-2008, 03:01 AM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
A+ for the DYI and the banana costume.
As for your photographer's focusing skills...
Old 11-26-2008, 01:30 PM   #3
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
heh sorry.. i have a shitty digi(most of the pix i usually take that y'all have seen are with my celly.. and by darnit, i happened to leave it at jamesons house! bah.. will get it later.. but ya.. we were kinda rushed a bit and then come to find out he didnt have an oil filter socket thing.. homie did that ish by hand with a wrench.. do what ya gotta since it was 9pm so everything was closed...
now seeing as iv witnessed and assisted this oil change procedure.. now imma be cool and do my own too!
Old 11-26-2008, 01:56 PM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
One change I would make -
Make sure you break the oil filter loose BEFORE you drain the oil. You don't have to pull it off, just make sure you can turn it. That way if you have a problem getting it loose you can go get a proper tool and not be stranded.
Old 11-26-2008, 03:08 AM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
Dude...5 qts. is WAY too much. The car should only take 3.5-3.8 with a filter change. Overfilling with oil can do SERIOUS DAMAGE to your engine!
Good DIY otherwise!
jkuchta is offline   Reply With Quote
Old 11-26-2008, 03:25 AM   #6
Ace
Drives: 2008 Yaris Sedan
Originally Posted by id3379 View Post
The recommendation is 4.3 quarts from a dry fill, i don't see how 5 is over doing it ? You couldn't even see the oil level if you looked in the head through the oil cap hole. And i've always used 5 quarts in my 1.5 liter 4 banger's from honda's to toyota's. Never had any problems at all.
it's your car... so do whatever the hell you want.
Ace is offline   Reply With Quote
Old 11-26-2008, 09:21 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
Also, thanks for poiting out the correct amount. i owe you
the "serious damage" is really just oil foaming.. because there's more oil in the sump, it's "sloshed" more by the crankshaft which keeps it foamy.. which means air bubbles are trying to lubricate the REST of your engine.. not very effective lubrication and very poor cooling properties
Old 11-26-2008, 04:40 AM   #8
jkuchta
dry fill is no oil in the engine after a rebuild.......not an oil change with a filter. Also, a yaris is not a Honda. Do me a favor and take a look at the oil level on the dipstick and tell me how far above the high mark it is.
Old 11-26-2008, 07:06 AM   #9
elmo
WFO
elmo's Avatar
Drives: 2008 hb
it was a quarter of an inch above the line
trust me you ain't doin you engine a favor overfillin your oil
but hey it's your car
elmo is offline   Reply With Quote
Old 11-26-2008, 07:19 AM   #10
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
That means that you are about a quart of oil over the limit
YamilR is offline   Reply With Quote
Old 11-26-2008, 04:53 AM   #11
Ace
I think it's 12 quarts before you can see the oil from the cap so why stop at 5?
Old 11-26-2008, 09:12 PM   #12
Benggolf2
Benggolf2's Avatar
Ohhhh, nasty but funny as hell!
On a serious note, wait for the oil to settle down (give it at least 10-15 minutes) after a drive and check your oil level carefully. Too much oil will cause your crankshaft to splash on the oil inside the crankcase and ..... create too much bubbles (like milk shake, eh) and consequently your engine lubrication will be compromised.
Benggolf2
Old 11-26-2008, 09:53 AM   #13
06silveryaris
Drives: 2006 yaris
I have always overfilled when prepping for a trackday since I did not run a baffled oil pan. This was on Hondas only but for the yaris I just do 4qts.
06silveryaris is offline   Reply With Quote
Old 11-26-2008, 11:08 AM   #14
jkuchta
I'm not mad at the guy...I just don't want him to make a simple mistake and possible spin a main or rod bearing on a pretty much new engine in a great looking sedan.
06silveryaris, this last weekend I ran my oil level about halfway between full and low (about 3.2 qts. with filter at the change) on the dipstick, and never saw any fluctuation in oil pressure. Running too much oil, especially on the track, can lead to a dangerous loss of the oil's cooling and lubricating abilitys due to foaming (Thanks for elaborating Tomago).
Old 11-27-2008, 11:23 AM   #15
06silveryaris
Drives: 2006 yaris
never thought of that, I will def try it next time out. thanks
Old 11-26-2008, 12:21 PM   #16
gid
Drives: '08 Yaris sedan , '08 Liftback
otherwise well done . You should start your own show on the food channel . Oil and good 'ol HELPER are similiar . Just FUELS for thought .
gid is offline   Reply With Quote
Old 11-26-2008, 06:44 PM   #17
Chupacabra
Drives: 2009 Yaris liftback
A few things I would change....
1) Engine and oil should be HOT to change the oil...don't let the car sit for an hour
2) Open the filler cap after you open the drain plug
3) Use wheel bearing grease to lube the filter gasket and spin on hand tight
4) I think that you let the car down before putting the drain plug back in. That's an important step.
Chupacabra is offline   Reply With Quote
Old 11-26-2008, 06:55 PM   #18
rstb88
rstb88's Avatar
Drives: Silver Hatchback
I disagree with the above, it doesn't need to be hot but not cold. Warm enough to run out smoothly not hot enough to melt gloves to your hand(running temp). Filler cap doesn't matter when opened, aslong as you open it. I would never use anything on a seal that would touch my engine oil unless it is the same oil(old or new) Granted its not much grease, but its an undesired product that may or may not contaminate my oil. Don't have to be down to put the drain plug it just gotta be down before you start the car and check the levels. Aweful hard to get under a Yaris to put the plug back in when its not on stands. I've always use old oil, 1 because unless I see metal flakes or grittyness I feel that it is safe to use 2 my finger doesn't reach far enough into the new oil to get some.
O I'm envious of that stove, I want it. It looks like either a Viking or Wolfe.
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY - oil change kurokoma-kun DIY / Maintenance / Service 7 11-20-2008 12:12 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
