Old 12-26-2015, 05:01 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
DIY tool for fuel tank lid
There has been more discussion as of late about fuel pump and regulator access so here are a few photos of the DIY tank lid tool I made. 1" steel pipe. We cut a 3" section off of the length of pipe I bought and then sliced it down the middle to make two half moon sections. I then welded them as you can see so that they will grip the teeth built into the lid. The length of the bar is 30" to give plenty of ability for torque to remove/reinstall. I have used it probably well over a dozen times with no issues. Hope this helps people. This is a much cheaper alternative to the Toyota tool that costs hundreds of dollars.
Sent from my XT1575 using Tapatalk
DIY: 60/40 Split Seat Install (some welding required) CTScott DIY / Maintenance / Service 13 03-05-2017 05:12 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 04:57 PM
tool list silver_echo Off-topic / Other Cars / Everything else Discussions 5 10-21-2010 11:23 PM
