Old 10-15-2013, 09:36 PM   #1
wolverine565
Drives: 2008 toyota yaris
won't start after broken radiator
My radiator got broken and leaked out all fluid. The engine shut itself down. When it shut down, no matter how far I pushed the excelerator, I could get any rpms. I replaced the radiator. The engine turns over, but won't start. Is there a interlock that I need to reset to get the care to start?
wolverine565 is offline   Reply With Quote
Old 10-15-2013, 10:08 PM   #2
There is not an interlock. If it overheated to the point where it shut down you may have done some significant damage to the engine. The first failures at that point would be a blown head gasket and/or a warped head.
Old 10-16-2013, 12:11 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Someone didn't see the red overheating light to me..
Old 10-16-2013, 05:33 PM   #4
esse10
Drives: 2009 yaris 2 door
temperature light
I hate that Toyota did not put a temperature dial gauge in these that way folks can see if their cars are running a little hot or close to hot and stop before they boil over-bad news man. By the time the little temperature light comes on it might be too late, damage done already. You need to make it a habit to check your coolant level at least once a week to be on the safe side and anything out of the ordinary needs to be investigated thoroughly before it becomes a real problem and leaves you stranded or worse like Damaged engine block. I feel for ya bro
Old 10-17-2013, 10:47 AM   #5
IllusionX
i've missed 1/2 qt and never overheated.
There shouldn't be any damages when the lights come on. It means you are in the red.. set yourself aside and shut off.
Driving it beyond engine self shutdown will certainly cause damages!
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 01:58 PM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 11:02 PM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 03:20 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 11:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 09:53 AM
