Old 10-30-2013, 10:44 PM   #1
dinop
dino
dinop's Avatar
Drives: '07 Toyota Yaris (sedan)
Used Yaris, Some Problems
I just 'inherited' a 2009 Toyota Yaris Sedan from my parents. I took it out for a test run today and noticed a few things that I'd like to correct. First, the dome light does not come on with the doors, even though the bulb has not burned out (I switched it to "ON" to check) and the dome is set to DOOR. Also, there is no audible light, seatbelt, or door buzzer. How can I fix these issues? I'm not entirely concerned about the dome light, but I'm a pro at leaving my headlights on so I'd really like the audible warning back.
Thanks in advance,
Dino
The high-mileage club is like the mile-high club...in no way
Dino, VT
07 Toyota Yaris Sedan- stock, 281k, daily driver
09 Toyota Yaris Sedan- stock, 128k...parents car
95 Audi S6- alt daily driver, 5 cyl turbo, 224k
75 Triumph TR6- Current restoration project, 8k
dinop is offline   Reply With Quote
Old 10-30-2013, 10:59 PM   #2
The dome light in "door" mode is controlled by the body ECU and the key/light reminder is fed to the cluster by the body ECU as well.
I would start by checking the ECU-B fuse in the under hood fuse box, and then the ECU-IG, ACC, PANEL1, and MET fuses in the under the bottom of the dash fuse box.
Old 10-31-2013, 12:26 AM   #3
Hershey
It's likely to be the door switch of the drivers side ( located on the door jam(?) ) . We had ours replaced and is acting up again . The rear door on drivers side does the same thing . Everytime we bring it to a service center the dome light and alarms decide to work . Why this is an issue is beyond me . Never had it with other cars .
Old 10-31-2013, 11:24 AM   #4
If it is the door switch, then the door icon will not illuminate on the cluster when you open the door. I am surprised to hear of one failing. They are a simple and robust switch. If you need a replacement I have a few on hand.
Old 10-31-2013, 07:07 AM   #5
bronsin
bronsin's Avatar
Golly gee is there a way to disable the key/seatbelt/door alarm?
Old 10-31-2013, 09:37 AM   #6
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
You mean the beeper?
Get Techstream, cr4ck it, take a "mini vci" and there you go ;)
dj92 is offline   Reply With Quote
Old 10-31-2013, 10:58 AM   #7
bronsin
bronsin's Avatar
Whassat?
Im 57 years old.
Old 10-31-2013, 12:16 PM   #8
Hershey
We had 2 replaced under warranty . Driver side door and the passenger rear . Still have Platinum warranty to cover it . Thanks for the offer .
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 12:31 PM
la transmisión de mi yaris tiene big problems!!! toro yaris pr Caribbean 51 03-30-2011 03:45 AM
Yaris problems (not) fearturtle44 General Yaris / Vitz Discussion 15 01-16-2007 02:49 AM
