Old 04-06-2007, 10:29 PM   #1
NonStopTuning
New product from NST is in development...
OK OK, so its not for the Yaris, but with the recent talk around here about the AE86 and other Toyotas, I thought you guys might like to see these...
NonStopTuning Adjustable Cam Gears allow for the tuning of camshaft timing to effectively increase engine performance and tailor power output for various race applications. Compatible with either OEM Toyota or aftermarket camshafts, adjustments can be made to tune the 4AG power band to the optimum range for each particular application.
NST Adjustable Cam Gears are built using steel outer rings paired with hard anodized 6061-T6 center hubs to ensure the most durable and best fitting design possible. The NST 4AG kit is one of the few available with the quality of a factory fit, finish, and craftsmanship.
SPECS AND BENEFITS
• Increased adjustability of camshafts
• OEM Toyota outer rings for exceptional belt fitment
• CNC machined center hubs using 6061-T6 aluminum
• Each hub hard anodized; Most durable method in industry
• Six black hex bolts and washers used to prevent "slippage"
• All gears engineered, manufactured, and assembled in the USA
These pieces are currently in the final stages of testing. We plan to continue testing these pieces on one of our FORMULA DRIFT cars this season, as well as another NST sponsored car that does GYMKHANA stuff, before we release these in a few months.
NST FTW
MIKE @ NST
www.NonStopTuning.com
Old 04-06-2007, 10:33 PM   #2
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Tres cool!!
2006 Red Blitzed RS 5-door
Old 04-06-2007, 10:39 PM   #3
ChinoCharles
Drives: LB
Need I say more?
NST FTW!!!
Product Developement TDA Performance Modifications 21 06-04-2007 09:13 AM
ZPI or NST crank pully? PetersRedYaris Performance Modifications 35 03-04-2007 04:34 PM
ZPI V. NST Pulley shootout ZPIracing Performance Modifications 2 02-23-2007 05:45 PM
finally found a good product to clean al plastic parts Adriaan Wash, Wax, Detailing, Exterior Repairs 4 12-01-2006 03:45 PM
K&N Is looking for 2007 Yaris for Intake Development. Knfilters Performance Modifications 9 06-28-2006 05:34 PM
