Old 12-21-2013, 12:49 PM   #1
Lokariopr
Drives: Yaris 2014 HatchBack
Spacers Adapters 4x100 to 4x108 1"
I bought 4 rims 17" 7.5 for my Yaris 2014 but unfortunately are 4x108 and the Yaris is 4x100. I searching solutions and 1 solution is buying spacers 1 inch that convert the bolt pattern. My doubt is: If I install the rim with the spacer , don't make me any problem? The wheel don't touch the fenders or something? Please I need help.
Lokariopr is offline   Reply With Quote
Old 12-21-2013, 03:29 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
what is the offset of those wheels?
even without knowing what the offset is im pretty sure you're going to rub. The offset is probably around +25-45 and that would mean after the spacer youre sitting effectively at 17x7.5 +0-20. if you're running 195 or 205 you will not have enough stretch to clear the fenders without modification.
Old 12-22-2013, 03:44 AM   #3
TOLMACH
Drives: soarer
I have 17 by 7.5 with 205 40 tires. Car is dropped by around 1 inch with 1/2 inch spacers.. no rubbing at all
not sure about the offset.. i think it is 35 or 38
Old 12-22-2013, 12:05 PM   #4
Do some measuring. A 1" spacer is going to push your wheels out quite a bit.
4x108, adapters, rims, spacers, wheels
FS in FL: Spacers, 32MM 4x100 DJ_SpaRky Items for Sale by private party 8 07-27-2011 03:27 PM
4x100 --> 5x130 adapters sasquatch Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-30-2010 09:46 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 08:10 PM
4x100 to 5x112 adapters???? contraband831 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 02-12-2009 06:58 PM
