Old 05-20-2013, 02:29 PM   #1
jesusworship819
Drives: 08 toyota yaris 5 speed
2007 Yaris blinkers don't work HELP
Yesterday I changed the rear bulbs and believe I might have blow something. I just can not find out what it is. The hazard lights work but the blinkers do not. Also the car will only shift out of park if you use the shift bypass. Any tips or hints as to what I need to replace?
jesusworship819 is offline   Reply With Quote
Old 05-20-2013, 02:42 PM   #2
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Did you check the fuses? Next, a bulb might not be seated right. I would take the bulbs back out and recheck your work. Look for damaged wiring.
Final thought: Try resetting the ECU by removing the Neg battery terminal for 10 minutes, then recheck.
Amdkt7 is offline   Reply With Quote
Old 05-20-2013, 02:44 PM   #3
You popped the 10A GAUGE fuse in the fuse panel that is under the bottom of the dash. That fuse feeds both the shift lock ECU and the turn signal flasher.
Old 08-29-2013, 09:34 PM   #4
Youngbleeze
Drives: Red 2008 Toyota Yaris
Send a message via AIM to Youngbleeze
you just saved me $350 sir
08',trd sway bar, tint,sounds,rims,HIDs,DC exhaust,N.E.R.D decal lol and hopefullly more to come
Youngbleeze is offline   Reply With Quote
Old 08-30-2013, 12:42 AM   #5
Chuck G
Drives: 2010 Yaris Sedan
That's what he does!!
Old 05-20-2013, 02:47 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Old 05-20-2013, 02:48 PM   #7
YarisSedan
+1 scott said check the 10amp fuse.
Old 05-20-2013, 02:52 PM   #8
jesusworship819
If I remember correctly. I only saw one 10 a fuse in the panel under the dash last night. Bit was on the left side. Is that the fuse you guys are talking about. Thanks for the quick responses!
Old 05-20-2013, 03:04 PM   #9
No. look under the bottom of that area (literally up under the bottom of the dash) for the panel.
Old 05-20-2013, 03:09 PM   #10
jesusworship819
I will. Thanks Scott I will give it a shot tonight when I get home
Old 05-20-2013, 07:37 PM   #11
jesusworship819
Replaced the 10a fuse. Now the lights and the shifter work. HOWEVER now my ac will not turn on. No air blows out of my ac. Lights on the nobs work but no power. Where can I check for that. I figure it is another blown fuse. I checked in the same panel under ac and that fuse is not blown. Any suggestions?
Old 05-21-2013, 07:22 AM   #12
The 10A GAUGE fuse is the control fuse for the AC as well. Check the 40A HTR fusible link (one of the square fuses) on the face of the under-dash fuse panel. That one supplies the high current feed to the blower.
Old 05-20-2013, 07:44 PM   #13
Amdkt7
Returning to Toyota
I'm guessing the fan does not run whither heat/no heat/ac is selected. Probably a fuse for the fan that is separate from the AC.
Just joking, maybe you should not work on cars?
Really, it is hard to imagine what you could have done to cause this many problems just changing tail lights. Did you per chance do any thing else at the same time?
Old 05-20-2013, 11:50 PM   #14
jesusworship819
HAHAH Well the reason I had to replace the tail light(s) is because someone threw a rock at my wife's rear brake light and busted the housing and one of the bulbs. I will say though I don't think I have ever had one get this buggered up over nothing. I just wondering what will happen when I change the oil next time....blown head gasket??....front bumper falls off??...The possibilities are endless
Old 05-21-2013, 08:06 PM   #15
jesusworship819
I know this is turning out to be car maintenance for dummies. Buuuuuuttt. If you are talking about a fuse on the panel above when i replaced the 10a fuse I do not see a 40a fuse there. Am I just missing it or am I not seeing the right thing or looking in the right place?
Old 05-21-2013, 09:08 PM   #16
jesusworship819
Alright here is the tally. Rear back up lights do not work. Ac or heater do not work. Blinkers work. Shifter works. I have absolutely no clue how everything got this screwed up. Checked all the fuses I could find and they all seem fine(Replaced the 10a gauge fuse like ct scott recommended). This might turn out to be one of those take it to the people that get paid to do this kind of situation. This is just crazy.
Old 05-21-2013, 10:54 PM   #17
The back up light runs off the GAUGE fuse as well. Are you sure that the new one you put in did not pop as well?
Old 01-14-2014, 01:43 PM   #18
jwoehrle
Drives: 2007 yaris liftback
2007 yaris blinkers don't work!!
Here it goes.. I already know I did something extremely dumb however I know being completly honest may help diagnose this easier. I was installing new aftermarket tailight assemblies on my 2007 yaris liftback.. stupid me was in a hurry and I wasn't paying attention..did it while the engine was running.. now heres the problem. blower does not work at any fan speed. also the light that indicates rear defroster is on, is constantly lit now. if i put the blower in any speed other than off, or OR push the button to power on the rear defroster, then my signals wont work
jwoehrle is offline   Reply With Quote
2007 Toyota Yaris Hatchback - 5-Speed Manual truebreakerz Cars for Sale by private party 23 09-17-2009 10:29 PM
