Old 12-28-2013, 08:26 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
fuel pump
does this look like a real new pump for the 1.5?? seems cheap....
http://www.ebay.com/itm/Fuel-Pump-St...-/231051671953
yaris9876 is offline   Reply With Quote
Old 12-28-2013, 09:57 PM   #2
That is the correct one. The OEM one is made by Denso, so that Aisan is an aftermarket one.
Old 12-28-2013, 10:56 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
just curious....why do you think that you need a new fuel pump? aren't you also the chap looking to do a motor/trans swap as well? if so then it sounds like you have a lot of work you are putting into the car for sure.
Old 12-29-2013, 04:28 PM   #4
yaris9876
just buying a little time... my hatch has no power on acceleration (good at idle)unless I pump the pedal.
I cleaned the entire fuel system except the pump and filter in the tank. I put in new injectors,cleaned throttle ,all other stuff and OCV too. If it isnt the pump/regulator at 400K miles, then its the computer.
the engine swap is going to take some organizing and time.
Old 12-30-2013, 12:00 PM   #5
UberSilver
UberSilver's Avatar
Looks new enough, as I bought one. Thanks.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 10:27 AM
Fuel filter or Fuel pump :( tyrone_yaris DIY / Maintenance / Service 2 05-08-2012 01:32 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
