![]() Drives: 2010 5-door hatchback Join Date: Apr 2010
Driver Window Weatherstrip problem?
Hi,
I got a new 5-door Yaris six months ago. I like everything about it except this one little annoying problem: the horizontal weatherstrip (the one that looks like a long squegee) of the driver side does not touch the glass. When I roll the window down, it does not get wiped. (it works fine on the passenger side). Has anyone encountered this problem? Any solution? Thanks ![]() Michael |
You can take it back to the dealer and have them check to see if the wiper seal is installed correctly and/or adjust the window tracks/mechanism so the window contacts the wiper seal. It should be covered under warranty since its a workmanship issue.
-or- It should be something you can do yourself if you are even slightly mechanicaly inclined. I havent been inside the doors on my Yaris yet but every other car that I've had has room to adjust the window tracks/mechanism so you can get the window into the proper position. For starters ,here is the Yarisworld 30 second door panel removal DIY (for the lift back Yaris). CLICK ME
DAT'S RIGHT I GOTz 2
take it to the dealer, have them look at it since its still under warranty
if they find signs that you messed with it they might not cover it under warranty |
Thanks
Great, thnks guys for the great advice.
I will take it to the dealer then. So your Yaris doesn't do that, does it? both windows get wiped fine when the window is rolled down/up? Thanks ![]() Michael |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
My 2007 HB wipes the windows of rain, dew and very light frost, by cycling them down and up.
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
My Yaris doesn't wipe off anything from the windows, too.
resident senior
Mine does the same thing . So did my Evo . I just use the 55 mph method in conjunction with Rain-X . No problems ....
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
it is not a flaw. the seal is there to keep garbage
out of the door when the window is up when you drop the window it is not designed to keep the seal pinned against the glass. if it does fine, it is does not that is not a flaw many vehicles work the same way. it is not a -wiper- |
yeah.. it's not a wiper :P
it's supposed to only touch the window when it is up... I would rather have it not touch the glass at all... one less thing that scratches my window! |
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 06:13 PM |
| DIY: Colibri Power Window Install | Taiyaki | DIY / Maintenance / Service | 15 | 04-28-2016 09:03 PM |
| Help: Rear Door Small Window Install | nick.dollimount | DIY / Maintenance / Service | 7 | 09-22-2010 02:22 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
| Cannot open the driver door when unlocking from the outside. | Rahxephon | DIY / Maintenance / Service | 10 | 12-02-2006 09:18 AM |
