Old 01-06-2014, 01:10 PM   #1
as92
Drives: 2007 toyota yaris sr 1.8
keyless entry system fault
Looking for a bit of help, my keyless entry system has developed a fault after changing the remote battery.
The key still unlocks and starts the car but, When I walk up to the car the actuator engages 5 or 6 times before the lights flash and I can open the door.
Once inside the car, when you turn the ignition on the actuator engages another few times
Anybody had this problem or know whats going on?
as92 is offline   Reply With Quote
Old 01-06-2014, 01:36 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You might have missplaced the buttons when you reassembled the key
Old 01-06-2014, 03:08 PM   #3
as92
Thanks for tge reply.
Just took the key apart and carefully put back together again - its still doing it
Old 01-06-2014, 03:50 PM   #4
Bluevitz-rs
try using it taken apart. I suspect that somehow the plastic is pushing the buttons when you squeeze the key or twist it in the ignition to start it.
Old 01-07-2014, 09:30 AM   #5
as92
Tried that last night, then realised its both keys (its keyless start as well)
Old 01-07-2014, 09:34 AM   #6
Bluevitz-rs
Have you tried disconnecting the battery from the car and letting it reset?
Old 01-07-2014, 08:05 PM   #7
as92
I tried that today - no joy, I did realise also today that my o/s/r door does not open...
Old 01-07-2014, 08:08 PM   #8
Bluevitz-rs
o/s/r?
Old 01-07-2014, 08:09 PM   #9
Bluevitz-rs
can you take a video of what it's doing?
Old 01-07-2014, 08:15 PM   #10
Does the push to start switch LED flash either amber or green for 15 seconds when you enter the vehicle?
Old 01-08-2014, 03:42 PM   #11
as92
Drivers rear door sorry, below is a link to the video (just uploaded to youtube so hopefully it works) apologies for the poor light
The push start light does not flash
Https://www.youtube.com/watch?v=Q7vG...e_gdata_player
Old 01-08-2014, 04:21 PM   #12
OK. If the PTS LED does not flash. then the smart entry system does not believe that there is a problem. It seems to be isolated to the driver's side door oscillator.
If you approach the passenger side or the hatch, do they unlock properly?
Old 01-08-2014, 04:00 PM   #13
Bluevitz-rs
It says video is private for me.
Old 01-08-2014, 04:16 PM   #14
as92
Sorry, changed the privacy settings there, should work now
Old 01-08-2014, 05:00 PM   #15
as92
No, neither works. Could it be continuously trying to unlock the rear door? (as it is not opening)
Old 01-08-2014, 05:49 PM   #16
It might be the multiple clicking of the front door that is causing the system to not respond to the other doors. Perhaps the switch on the door handle is internally stuck, so the system is constantly seeing that door as attempting to be opened.
Old 01-08-2014, 07:21 PM   #17
as92
Think its worth stripping the handle down to have a look?
Old 01-08-2014, 07:25 PM   #18
Maybe. It is a bit of a hassle to get to it, but under the rubber square is a small switch. I haven't taken apart the door handle one, but I've taken a hatch one apart.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Yaris L power windows and Remote keyless entry system with lock josevenezolano Third Gen Yaris General Discussion 12 06-04-2012 01:34 PM
keyless entry system DOMAV General Yaris / Vitz Discussion 6 08-21-2009 05:02 AM
