![]() Drives: yaris Join Date: Jan 2014
YarisT Sport 2005
Hey guys, i have a 2005 yaris t sport with a problem, the odometer or the trip do not display at all? i have removed the instrument cluster, i have found 8 points on the underside of the pcb board, i believe a dil eeprom is on the other side of the board and i can connect via these points below? correct me if im wrong? i do not want to take the needles off as they don't look like they can be removed without damaging them? i have also read that the eeprom on these yaris sport's is rotated so i have attached the pictures of the points and the connection points (once rotated) but i cannot read any data from this chip using these points? am i doing something wrong?
it could only be one of these 2 options above depending on which direction the eeprom is situated!
The EEPROM pinout will not be interlaced like that. It will either be :
8 1 7 2 6 3 5 4 or 4 5 3 6 2 7 1 8
so are the eeproms not "rotated or inverted" on these?
like on here
I don't read German, but I assume that he is talking about which pins on his programming device go to which pins on the 93C46. You would never see a standard part number like the 93C46/LC46 where the pins locations are changed.
i thought that swell but I've also got this in english which clearly states the pins on this particular eeprom are different? you never heard of this ever?
#8 | |
If you connect yours per that and you still get no response from the EEPROM, then there is likely a larger problem with the odometer than the EEPROM needing to be reprogrammed.
oh right, I've got a few different programmers, one is a Diagprog 3 which im hoping also will automatically swap pins for me, but im going to try and read it later and i will find out. Do you not think reprogramming the mileage data will sort the issue? if not i may load a dataset for a yaris, i have a few, do you have any in miles from a 2005 sport C46?
#10 | |
Unfortunately I don't have any MK1 dumps.
ill give it a go, thanks for your advice anyway, ill post results
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Hey diagtech, would you mind posting about how you can access the EEPROM and modify the data ? I have been unsuccesful in looking for that information and that document you have looks interesting. I would like to fix the milage on my replacement meters.
Thanks. |
| [WTS] Brand New Sport Rims | 1151127 | Items for Sale by private party | 20 | 03-22-2013 12:28 AM |
| FS: 2003 Yaris T Sport | AlanH | Cars for Sale by private party | 3 | 07-06-2012 09:14 PM |
| 2005 Rear Undercarriage Pic Needed? | gapi | Cosmetic Modifications (Exterior/Interior) | 0 | 09-21-2010 06:52 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 07:42 PM |
