View Poll Results: What do you consider the best size, when considering everything?
14" 8 6.61%
15" 55 45.45%
16" 40 33.06%
17" 17 14.05%
18" 1 0.83%
Voters: 121. You may not vote on this poll
Old 12-27-2009, 02:02 AM   #1
Kal-El
Kal-El's Avatar
POLL: All things considered, what's the best wheel size for the Yaris?
Even though I'm offering my opinions, I'd like to see how this poll adds up and hear everyone else's opinions and pro's and con's with different sizes.
14" - IMO, too small
15" - IMO, the most practical with more (and cheaper) tire choices - tires generally last longer and rims are resistant to pot hole damage.
16" - A nice compromise between the attributes of 15's and 17's.
17" - IMO, the "best looking" size. Big, but not too big. But presents potential problems with low pro tires (pot holes). Tires have short tread life and are getting expensive
18" - IMO, too big although can look OK with a drop. The mentioned issues with 17's are multiplied
Old 12-27-2009, 02:08 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Being its a subcompact i would put anything larger than a 16. Thats my my opinion. If your talking cosmetics and dont care about anything else than maybe 17.
Old 12-27-2009, 02:11 AM   #3
16" rocks, fills the wheel well, looks great, still gives excellent performance characteristics.
Old 12-27-2009, 04:52 AM   #4
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
15
Old 12-27-2009, 06:10 AM   #5
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
I feel 15 to 16" wheel is the BEST set up for our tiny 1.5litre engine.
I've tried many 15" and finally got a chance to try 17" wheels for the look. After couple of weeks, i decided to go back to 15" again for more benefits rather just going for "cool" looking 17".
16" is will be good if you've turbo or super charge your ride. If not, try to stick to 15" for the cheaper cost of tires, more choice of of tires, better acceleration, better mileage per tankful & shorter braking distance(lighter rims).
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 12-27-2009, 11:27 AM   #6
Kal-El
Kal-El's Avatar
Thanks for the replies and votes so far.
Looks like 15's are ahead. The tire options are certainly plentiful in the 185 or 195/60/15 size. And it's amazing the price difference even from 16's. And when you consider you can get 15's to last up to 90K while the longest lasting 16" for the Yaris is warranted around 65K but typically around 40K. That alone is something strong to consider.
When I first started thinking about what wheels I was going to get I really leaned toward 17's for the most "show". Then I began thinking 16's was the best way to go. Still practical, enhanced looks, ect.
In the last week though, I'm suddenly thinking of getting rims in the stock size. I'm starting to not mind the taller sidewalls. I feel that from a practical, economical, and performance standpoint, 15's on the Yaris can't be beaten.
I first planned a purchase a while ago but finances got in the way. Then going into this winter I decided to throw on a winter set of tires on the stocks which leaves me with this choice in the early spring.
Deciding size, I find, is as hard as deciding on the style of rim itself.
Geez.
Old 12-27-2009, 10:57 AM   #7
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
15" for sure. Very light, they fill up the wheel wells reasonably well, and tires are cheap and plentiful.
Old 12-27-2009, 11:42 AM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
I do not see 19's or 20's? WTF?
Old 12-27-2009, 11:46 AM   #9
Kal-El
Kal-El's Avatar
You're kidding right?
Old 12-27-2009, 02:06 PM   #10
MadMax
MadMax's Avatar
I like 17" wheels, if only because that is what I am running...
Old 01-26-2014, 05:51 AM   #11
stevens_uk
stevens_uk's Avatar
Drives: Yaris Sport 2014
Best looking yaris i've seen to date! what brand are those wheels?
stevens_uk is offline   Reply With Quote
Old 01-28-2014, 07:36 PM   #12
Kal-El
Kal-El's Avatar
Wow, a 4 year bump.
Old 12-27-2009, 02:16 PM   #13
YAR1S
YAR1S's Avatar
O.O how did you get that close to the air force one? or is it on display? HAH
I tried to even watch that plane take off at my local airport and I felt like I was being watched...it felt like every single official in the world was there at every street corner.
-Jen <3
Old 12-27-2009, 07:35 PM   #14
yarstar
Drives: 2008 Absolute Red HB
I've run 17" and 15" and to me, the 15's BY FAR worked better. The 17s bogged down the engine and killed my takeoff, but I still ran them for about a year. I got sick of being slow, and bought some 15" Enkei RPF-1s. MAN, WHAT A DIFFERENCE!! I lost a little bit of handling by stepping down, but made up for it and went way past what the 17s could do by getting coilovers. I'd like to try some super light 16" one day, but for now I'm super satisfied with my 15"s.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 12-31-2009, 08:27 AM   #15
elmo
WFO
elmo's Avatar
Drives: 2008 hb
that is an old plane i think it is a 707 the air force 1 that the pres uses now is a 747 i think they been using 747's since regans 2nd term i could be wrong on that date
elmo is offline   Reply With Quote
Old 12-27-2009, 07:52 PM   #16
DandiDani
DandiDani's Avatar
i have 17's which are great. my husband has 18's which isnt bad either.
Old 12-27-2009, 08:44 PM   #17
06silveryaris
Drives: 2006 yaris
I,m running 17 but will be switching to 15 shortly. To wooried about pot holes
06silveryaris is offline   Reply With Quote
Old 12-27-2009, 10:03 PM   #18
tomato
tomato's Avatar
15 feels grrrrrrrrreat!
Xa - Yaris steering wheel jcove Cosmetic Modifications (Exterior/Interior) 1 05-09-2006 09:04 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 12:38 PM
