Old 04-12-2007, 07:20 PM   #1
S69
Drives: Yaris hatchback
Questions on rims for experiance ppl >> Need help pls
Hi there..
I have a black HB baby, 07, i have some questions on rims
1- What is the best width for 17 inch that will not make any problem on the HB?
2- The same question above but with 18 ?
3- On 18 is there any problem on HB ?
4- The stock rims come with 5.5 width.. what is the max witdh i can put " the car is the 1.3 normal engin " ?
5- The stock rims 15 inch >> any i diea how much they wight ?? with out the tire.
6- What u guys mean by rubbing ??
7- What is the exact use of the strut tower bar and why do we need them ?
8- if 17 inch what is the perfect wight should i get them and 18 inch as well ?
9- If the i get the 17 or 18 > but they are the same diameter of the stock with the tire, and the same wight >> do i still have less power ? ????
10- how do i know the offset size is perfect for my car ?
I would be so thankfull for the experianced answers ...
thanks alot ..
S69 is offline   Reply With Quote
Old 04-12-2007, 07:33 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
All the time you spent making this list could have been time used wisely using the search box. Try it out, you will find the answers to all of your questions.
SPONSORED BY
Old 04-12-2007, 08:13 PM   #3
S69
well.... reading alot of answers and opinians make me confuse but when u read it from experiance ppl is better ... they give what exact u need to know ..
Old 04-12-2007, 08:18 PM   #4
brickhardmeat
Lonesome Cowboy
good luck, I really think you should give the search box a try, last time I am going to say that though, people have lots of different opinions
SPONSORED BY
Old 04-12-2007, 08:33 PM   #5
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Originally Posted by S69 View Post
Hi there..
I have 17 7.5 and no rub
i dunno
i dunno
i dunno
i dunno
when u turn, it touches the plastics inside (surroundings of the wheel) or even the paint outside cuz its so big (that didn't sound rite?? )
tightens ur front tires. Its kinda like it keeps them straight so u can take better turns...make sure ur lowered to the ground..thats adds more effect.
i dunno..18 is u dont trave lthat much...how much miles u put a day? bumps in ur place? holes? etc etc. condition, ur environemnt..how is it?
u will lose power no matter what unless u get the very expensive 17s or 18 inch rims tha weights very light. buy an intake and it will balance it a bit out
try going to tirerack.com or w/e...they ahve those calculators thingy. i dunno much bout that...ask other emembers or search.
thanks alot ..
-- Blen
Old 04-12-2007, 08:38 PM   #6
Blenjar
Blenjar's Avatar
Do a search on strut bars, etc etc.
ANSWER THESE QUESTIONS:
DO YOU TRAVEL A LOT?
WHAT IS THE ROAD CONDITION IN TOWN OR PLACE U GO TO A LOT?
DO YOU WANT TO BE ORIGINAL OR GET THE SAME LIKE EVERY1? (RIMS)
IF U WANT OTHER RIMS(WWW.WHEELWEIGHTS.NET)
RESEARCH AND FIND LOWEST WEIGHT AT A PRICE YOU CAN PAY, I KNOW I DID (stares at his bronze hanabis)(don't get mine!!!!!!! or I'll kill u)
IS IT AUTOMATIC OR MANUAL?
IF ITS AUTOMATIC, DON'T BOTHER GETTING STRUT...COME ON? UR NOT GONNA RACE R YA???? GET SPRINGS INSTEAD..TRD 1.5 DROP FRONT AND BACK, LESS KILL ON UR STOCK SHOCKS N STRUT UNLESS U BUY COILS COVER BUT HTATS SOMETHING ELSE.
Okay bye
-- Blen
Answer those questions.
Old 04-12-2007, 08:43 PM   #7
Blenjar
Blenjar's Avatar
oops, it doesn't tighten ur front tires, i meant ur front 2 shocks....
think of the front too shocks as legs, okay now it will keep them straighter. Look at hte picture and u will understand it..
Correct me if I'm wrong.
-- Blen
Old 04-12-2007, 10:04 PM   #8
S69
traveling i use my other car " 02 530 I "
roads r perfect here and smoothly
i want " wow " chrome rims to give wow look to the yaris >> got the piont ?
its automatic,, not for race.
im thinking also to go for 20 inch but it will make me go in other problems. engin cant handel the 20. its 85 hp only 20 will be havey on the engin.. maybe later on i might change the engin and put the 1.5 toyota xa or the 1.8 corolla but not now after a year maybe...
so for now i will go for 17 or 18 >> 18 is nice and look nice too.. with 40 or 35 tire...
Old 04-13-2007, 07:31 AM   #9
Blenjar
Blenjar's Avatar
So okay.
Go with 18 inch
Don't bother taking hte strut tower, you won't need them.
get an intake to balance the weight u added onto your car..
mmmget an exhaust
lower it a bit..go TRD if you want to keep ur stock shocks and strut in good shape other wise if you go lower, u will kill them faster and will have to replace them with w/e u want in a year or two.
just put a lotus engine in your car and you will fine. =]
-- Blen
Old 04-12-2007, 10:08 PM   #10
MrJester
Drives: homo
someone on here has 20s on there yaris not a recommendation but you can squeeze 18s under there no problem I think 17s look perfect you can also drop it with those and they look even better.
MrJester is offline   Reply With Quote
Old 04-12-2007, 10:24 PM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
17x7-7.5------- 215/40r17----- +40-45 offset if you are going to lower it
18x7-7.5------- 215/35r18----- +40-45 offset " "
20x7.5-8 225/30R20 Rock them Bitches, but you can't lower it, it will be fine with the 1.3L we only have 96 at the wheels with the 1.5L
Old 04-13-2007, 02:58 PM   #12
S69
thanks alot ..
is the tire will be out from the car or just exact with body coz i wanna lower it. i dont want the that look to my car " tires going out the body " with all the size u gave me ??
Old 04-13-2007, 01:36 AM   #13
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
do u guys have wheel spacers in the rears? i just wanted the rears to look almost flush with the fender.. but not totally flushed so that it won't rub... sorta off topic, but oh well, S69 had a bunch of questions already, might as well put it out there too! hehe
barebonedvitz is offline   Reply With Quote
