Old 02-21-2014, 10:01 PM   #1
7:34pm
Drives: 07 Yaris
Is there a top or bottom of the springs?
Installing the rear springs (Eibach pro-kit); is there a top and bottom?
At first I assumed the the tighter coiled area would be at the bottom, but that makes the Eibach logo upside down, which doesn't make sense for Eibach to do. Every pic I could find shows that the tighter coiled part sits at the bottom. Usually manufacturers place the logo right-side-up, which would put the tighter coiled area at the top. Now I'm confused but I don't think either way will make a difference...?
I've done a lot of suspension, however I'm not familiar with the Yaris.
Photo from Chris07LB
7:34pm is offline   Reply With Quote
Old 02-21-2014, 10:09 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Logo the right side up ....I got sport line on mine its how I installed mine will have a look tomorrow ...I thought pro where black .
Old 02-21-2014, 10:12 PM   #3
7:34pm
Drives: 07 Yaris
pro-kits are black, I just borrowed the photo
Old 02-21-2014, 10:13 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
www.catalograck.com/imgvd/EIB/d2151.pdf
Found this ...this may help
Old 02-21-2014, 10:16 PM   #5
7:34pm
Drives: 07 Yaris
"Logo right side up" Ok I can quickly fix that tomorrow.
Old 02-21-2014, 10:20 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Ya the second pic looks right ...tight on top
Old 02-22-2014, 12:32 AM   #7
Logo right side up is the standard for springs, including ours.
Old 02-22-2014, 03:48 AM   #8
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Dont mix up the left and right. LOL JK
Check out my Build thread:
Old 02-23-2014, 12:31 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
yeah.. i vote for logo always right side up..
Old 02-26-2014, 03:26 PM   #10
7:34pm
Drives: 07 Yaris
Ok back to it. End links were corroded and had to wait on new ones to come in. Noticing the front bump stops supplied by Eibach are narrower in diameter and loosely fit the strut top hat.
I'm thinking I should just reuse the stock and cut an inch off. What says YarisWorld?
Old 02-26-2014, 05:58 PM   #11
Pro-kits; I wouldn't bother with cutting the bump stops. Drop is not radical enough to really warrant it.
Old 02-26-2014, 06:57 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
i say use what came in the box ...but its only a 1 inch drop so stock should be fine too.
Old 02-26-2014, 07:41 PM   #13
7:34pm
Drives: 07 Yaris
I tried to use what was in the box but the bumpstops didn't fit snug in the top hat, it was like a pencil down a hallway. I just took an inch off stock and used it.
Old 02-26-2014, 07:58 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
that will work too....now go and have fun driving it
Old 02-26-2014, 07:59 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
o and post pics when done
Old 02-27-2014, 10:14 AM   #16
IllusionX
When i took out my original ones, one of the side had slid down.. so i don't think it was really meant to stay up
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 04:45 PM
FS: TRD Springs carguy Items for Sale by private party 5 04-02-2010 03:37 AM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 09:37 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 11:02 PM
