![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2007
Need serious Tire and Rim help
I'm gonna order some 17.5 inch rims, the dealer suggested 215/35/17, this is for my silver sedan, and I will not be lowering it. What is the best size tire that won't rub and that I can get the best mix of looks and practicality for this size rim? I won't be racing this car, I actually drive it like a grandma. Its just the steel 15 inchers are fugly.... I'm totally clueless in regards to tires and rims so please chime in with some pictures to show me the differences between 35's 40's and the like.
Thanks in Advance.... |
der Zeck
you dealer is wrong 215/40r17 is the correct size to keep the over all diameter correct
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
Why not a 205/45/17, more profile will help it ride a little better. Wont rub, and is pretty close to stock
der Zeck
too tall depending on the offset he goes with, and if it will be lowered, it will rub
I have 17x7.5 with no rub on normal driving only time I find rub is on large road bumps.
Honestly this needs to be moved to the tired section. |
205/40/17 is your best bet
![]() It's a Vitz! |
You must not trust my advice to make a post with the same question you PM'ed me about. Anyway, you got the same answer here so go with it.
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
True,Ive seen enough rim ?'s the past week.
der Zeck
der Zeck
it is not so much the wheel width, it hs more to do with the size of tire and the offset of the wheel that determines if it will rub or not
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 07:29 AM |
| yaris takes a blown tire really well | dbaxter | General Yaris / Vitz Discussion | 4 | 11-28-2006 05:14 PM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 04:25 PM |
