Old 02-27-2014, 11:41 AM   #1
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
Which way i go? I will be on 16x7.5 +35mm rim. Will i be on 205/50/16 or 195/50/16
Help me guys!! Which path will i go best??
I will be on Tein Basis CO's and wheels size will be 16x7.5 +35mm rim. which one will I pick for tires with out any rubbing issues. 205/50/16 or 195/50/16. Just to be safe. This will be for a daily car use not for track. But i want a low profile because i love driving fast taking the corners without any problem. . Please Please help!! Thanks.
daddz07 is offline   Reply With Quote
Old 03-12-2014, 06:10 AM   #2
grelise
Drives: 07 YR Yaris 5dr Hatch
I got 16x7 with 205/45/16, no scrubbing, could try this size
grelise is offline   Reply With Quote
Old 03-12-2014, 07:02 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
205/50/16 will likely rub and is pretty heavy. You should go with 205/55/15's instead, or even 50/15's if you want a lower profile tire, which kinda makes it look like 16s without all the extra weight. Sure, the speedo would be off by a little bit in that last case, but nothing to be concerned about IMHO.
If you're dead-set on 16s, then 205/45/16's would probably be a safer choice.
Old 03-12-2014, 09:38 AM   #4
daddz07
Drives: Yaris 2008
Thanks guys.i end up with 195 50 16.
Old 03-15-2014, 03:12 AM   #5
daddz07
Drives: Yaris 2008
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
