Old 05-20-2014, 12:57 PM   #1
Zarkos
Zarkos's Avatar
Drives: 2009 Toyota Yaris Hatchback
Exclamation What is wrong with my car?! D:
So I don't really know much about cars and I have no idea how this happened or what is happening. Could you guys please let me know what this is and how I might be able to fix it?
Any range on price?
Thanks for the help!
Zarkos is offline   Reply With Quote
Old 05-20-2014, 01:28 PM   #2
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
what the f is that?... did you spill (or someone else) some chemicals on it?
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 05-20-2014, 01:36 PM   #3
nortonfb
Drives: 2007
Looks like your clear coat is lifting.
Maybe Toyota's fault or caused by the environment.
Are you near a chemical plant or similar?
It would most likely require a new paint job.
Good luck.
Steve
nortonfb is offline   Reply With Quote
Old 05-20-2014, 02:07 PM   #4
If you do a search for "clear coat peeling" you will see quite a few threads about this issue. It seems to be only or most prevalent with Blazing Blue Yaris and prior to yours, it seemed to be limited to 07 and 08.
Those who have had the issue have not seemed to get very positives from Toyota as far as repairing it as a warranty item.
Repair involves sanding off the clear coat and reapplying it (which likely means well over $1000.
Old 05-20-2014, 02:18 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Where do you live?
Old 05-20-2014, 02:21 PM   #6
Zarkos
Zarkos's Avatar
Hey guys,
Thanks for letting me know what's going on. I live in Miami, Florida. I've never put any sort of chemical on the car or anything.
I was hoping that the repair might be less that $1000 though :/
How much is a new paint job?
Old 05-20-2014, 02:25 PM   #7
Originally Posted by Zarkos View Post
Hey guys,
A quality paint job would start around $7k.
It is interesting that all of the Yaris that I have seen with the peeling issue thus far have either been from the Southern US or from Australia.
Old 05-20-2014, 02:26 PM   #8
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Clear coat.
You will need to repaint the entire car, cause if you paint the roof by time other parts will get the same. Just paint it completely.
monchito18 is offline   Reply With Quote
Old 05-20-2014, 02:27 PM   #9
monchito18
monchito18's Avatar
Drives: Yaris sedan
O.o
Old 05-20-2014, 02:42 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
So therefore it is a heat/humidity related issue
Old 05-20-2014, 02:49 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
Wow that sucks! If it's just the roof you may be able to get by with just painting it black from a local shop. It looks pretty good and then you won't have to worry about matching the blue as paint fades over time and makes it harder to match, hence painting the whole car. I know caliyaris on his old yaris had the roof painted black (on white) and I have the meteorite metallic and have my roof black now. I didn't have the peeling clearcoat issue, was just getting my car custom painted and wanted the look for future airbrushing on the roof.
Just an idea. I was quoted $600 for just doing the roof in black.
Old 05-20-2014, 02:53 PM   #12
Zarkos
Zarkos's Avatar
Yea, it's not jut the roof. The roof is the worst of if. Some of it has started on the hood of the car but it's not that noticeable.... ugh, this shit sucks.
Old 05-20-2014, 03:11 PM   #13
IllusionX
Drives: 07 Yaris Sedan Aero
a cheap solution is plastidip the car.
Old 05-20-2014, 06:18 PM   #14
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
OR, sand it smooth, have it wrapped black. $300-400 and done.
Old 05-20-2014, 07:57 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea, plastidip will at least cover it up and protect the roof. plus you can do crazy things for cheap and just peel it off if you hate it. https://www.dipyourcar.com/home.php?...FVJnOgod1nsAYw
Colin Chapman disciple
Old 05-20-2014, 10:12 PM   #16
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
plastidip is not a bad idea in this circumstance.
phaznet is offline   Reply With Quote
Old 05-21-2014, 07:54 AM   #17
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
That looks like every toyota in FL lol
Old 05-21-2014, 09:58 AM   #18
IllusionX
How many gallon to dip the Yaris?
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 09:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 11:58 PM
