Old 03-23-2014, 08:55 AM   #1
bronsin
bronsin's Avatar
Cut the PS Belt?
Im thinking of cutting the PS belt on my 09 Yaris.
Besides losing PS is the car programmed to not run or something? Would the CEL go on? Anything bad happen at all? Talk me out of it if you can!
Thanks!
Old 03-23-2014, 09:00 AM   #2
There is not a PS belt on your 09 - It is electric PS.
If you cut the drive belt you would lose your alternator, water pump and AC.
Old 03-23-2014, 09:21 AM   #3
bronsin
bronsin's Avatar
OK! You talked me out of it!
Old 03-23-2014, 09:44 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
LMAO!
Old 03-24-2014, 12:01 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
that said.. how about pulling the fuse of the PS motor? that would throw a PS light, and likely a CEL too.
But then, what would you gain from disabling the PS? Train your arms?
Old 03-24-2014, 06:00 AM   #6
bronsin
bronsin's Avatar
In my current decrepit state I cannot pull the fuses!
A belt driven PS would gain mpg if disconnected, no?
I dont want a CEL as NJ inspection is due April 1st. All they do is check the computer for error codes in NJ.
Nothing else.
Old 03-24-2014, 08:56 AM   #7
MadMax
MadMax's Avatar
Nominal at best, if any at all; and since we've got electric power steering systems, it's a moot point...
There are much better/easier ways to improve MPG if so desired. I would research those before cutting anything!
Old 03-24-2014, 07:41 AM   #8
Bluevitz-rs
I've been running my echo without the PS belt for years now. I can't tell if I gained any mpg but the steering feel is WAY better. I really need to remove the pump and loop the lines though. I'm still pushing around cold fluid and it's pretty hard when you aren't moving.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
