Old 03-23-2014, 10:21 AM   #1
YHWilliam09
Drives: '09 Base 2-door Hatchback AT
Changing Automatic Transmission to Manual Inquiry
Out of curiosity, I'm wondering what all must be done to change an automatic transmission to a manual on an '09 Yaris Hatchback. I understand it may be quite expensive and labor intensive, but I still wonder what all is involved mechanically in such a switch. What parts would be needed to do something like this? Let's assume money and labor is not the issue.
YHWilliam09 is offline   Reply With Quote
Old 03-23-2014, 11:08 AM   #2
Time, money, tools, and guts.
http://www.yarisworld.com/forums/showthread.php?t=49003
Old 03-23-2014, 11:24 AM   #3
It's not as bad as it seems. I converted one the opposite way (MT to AT) and that way requires adding 19 wires the the ECM harness (or switching to an AT engine harness).
The sum of the parts could be crazy expensive, but with my kit in the link above, you are only looking at that plus the cost of a MT (used low mileage ones can be had for under $500). Labor-wise it is really about the same as dropping the tranny to replace the clutch.
Old 03-23-2014, 11:55 PM   #4
YHWilliam09
It's very tempting, but I can't quite decide whether I want to make the switch. I'd hate to spend the money and time and end up wishing I kept the automatic. Looks like a good deal for all those parts.
Old 03-24-2014, 10:11 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
ECU change well though correct?
Old 03-24-2014, 10:39 AM   #6
Correct. I have one 06-08 MT ECM on hand. 06-08 and 09+ are readily available used for under $100.
Old 03-25-2014, 08:58 AM   #7
YHWilliam09
CTScott, is there a choice with what kind of manual transmission I could put in an '09 Yaris as far as gearing goes (I'd prefer higher gearing), or are they all geared the same?
Old 03-25-2014, 09:16 AM   #8
There are no plug and play choices really. There are several threads here about performing an xB final drive swap. Search those terms to find them.
Old 03-25-2014, 11:25 AM   #9
^Exactly. You are really limited to the C50 transmission for a direct fit solution.
Old 03-25-2014, 11:28 AM   #10
YHWilliam09
Okay, thanks.
http://www.microimageonline.com/down...0Transaxle.pdf
To remove the automatic transmission, is doing all these things (starting on page 168) necessary? Looks like a big job.
Old 03-25-2014, 11:31 AM   #11
Originally Posted by YHWilliam09 View Post
Okay, thanks.
Yes. The stuff shown in that section only takes a couple of minutes to remove. The big pieces are disconnecting the shafts, and unbolting the tranny from the engine. All in all, for someone experienced it is probably a one day job.
should oil be changed in manual transmission? galactus DIY / Maintenance / Service 70 07-03-2024 05:56 AM
Does any other auto tranny Yaris owner regret not getting the MT? bentjazz Fuel Economy Forum 160 10-21-2016 07:12 PM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 07:14 PM
