![]() ![]() Drives: red Liftback Join Date: Aug 2007
Is there a simple way to install a tach in a 2007 Liftback?
I just installed a tach in my Ford E450 SuperDuty..Ford provided a single labeled Tach connection wire adjacent to my wiper motor under the hood. It took about 20 minutes to complete...mainly just running the connection wire through the firewall and connecting power wires to the fuse box. (Sweet)... I have looked under the hood of my new liftback and all I see are harnesses...do I have to 'cut' into the harnesses?!? Does the liftback have the same wiring harness as the Sedan?...I assume that all sedan harnesses must have a tach wire for the tach 'option'...so if the harnesses are the same...there should be a deadend connector somewhere under the liftback hood, right? |
![]() ![]() ![]() ![]() Drives: 2007 Toyota Yaris Blazing Blue Join Date: May 2007
If you would have scrolled down a little bit... http://www.yarisworld.com/forums/showthread.php?t=662
| Installed Tach...Tach works, RADIO doesn't! | 5spBlazer | DIY / Maintenance / Service | 17 | 08-06-2007 08:57 PM |
| RPM Gauge Install | rwseattle | DIY / Maintenance / Service | 1 | 04-15-2007 12:23 PM |
| Auto-Meter Silver Sport Comp Mini Tach | ChinoCharles | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 02-26-2007 05:14 PM |
| tach gauges install | dansides | General Yaris / Vitz Discussion | 0 | 02-01-2007 11:31 PM |
| Liftback - Easiest Way to Get a Tach and Cruise Control... | weeze-dog | General Yaris / Vitz Discussion | 60 | 10-20-2006 05:40 PM |
