![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
HVAC Fan
Hey guys..
I was talking to the wife today in the car and I had the HVAC set to speed 1, and she commented how loud a hum it makes... I always knew it was loud, but I guess over the years I kinda forgot how loud it was... How loud do you guys/gals find your fan when set to the first speed setting?? Again, it is a very noticeable hum sound at this setting.. And the cold really has not effect, and it is the same even in the summer.... Thanks everyone.. Last edited by CB900F2; 01-25-2014 at 09:39 PM. |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
No, on the first two settings my fan actually barely makes any noise. With or without a/c on.
off course on the second it does make some noise but it's easily drowned out by the radio.
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
If you do not have a cabin air filter installed the hum may be due to something having been sucked into the fan (like a piece of paper from the glovebox).
Hi Scott.. I had a cabin filter front new.. I did find a another thread and it was noted that toyota changed the part# of the blower around 2010/09 , so I am going to assume they revised the blower motor and maybe to address it being a bit noise.
Interesting - I just looked in the EPC and there are 2 different part numbers. 87103-52140 and 52141. I have 52140 on my 07 and 08 and 52141 on my 09. I don't hear a difference between them. The part number is on the center of the bottom of the blower motor.
Mine does make a little humming sound when it's running. I should make a video of the sound. Not sure how well it will turn out but i'll try...
I don't like the noise it makes, but i guess it's the way it is.. My Echo made the same noise. |
my Echo's doesn't make any noise other than the sound of air coming through the vents.
I just made a little 30s video of the noise my fan makes.
https://www.youtube.com/watch?v=w1ElLu9NW4M |
It just sounds like bad bearings to me.
He guys.. Here is a link to a video of the sound from my skydrive.. I hope the link works..
https://www.dropbox.com/s/f76wcj0uzu...D_00000007.mp4 Last edited by CB900F2; 01-26-2014 at 05:39 PM. |
900, that sky drive thing doesn't work for me. Can you put it up on YouTube or photobucket?
It definitely does not sound normal. I haven't taken one far enough apart to see if the motor has bearings or is simply a cheap bushing type motor. I have a couple of quiet spares on hand, if you would like to replace it.
Hey guys..
Ordered a replacement from rockauto, and installed it an all is good now....nice and quiet.. I decided to take apart my old one too see what was the issue, and when I took apart the motor, it was a bad bearing... It was a bitch to take off the fan , not meant to be serviced.. |
Cool. Any pictures you could take? Also, do you think you could put it back together and use it again?
![]() Drives: 2007 Toyota Yaris Join Date: Apr 2010
CB900F2: Do you have the part # for what you purchased from rockauto?
My fan's noist too... TIA |
Hi Fasteddie... The part search tool at Rockauto is very easy to use... There is only one supplier (TYC) listed..
| Anyone try a Ducted fan? | UberSilver | Forced Induction Forum | 5 | 06-07-2013 11:57 PM |
| HVAC BLOWER ISSUES | yaris2010RS | DIY / Maintenance / Service | 18 | 12-29-2012 11:23 PM |
| Fan Not Spinning Up, Random Airbag Light | drannonb | DIY / Maintenance / Service | 12 | 10-23-2012 03:33 PM |
| AC Blower Motor / Fan Does Not Turn on Period | dyslexicanaboko | DIY / Maintenance / Service | 7 | 01-30-2012 10:59 PM |
| Abnormal radiator fan | hi577 | DIY / Maintenance / Service | 0 | 01-21-2012 03:34 AM |
