![]() Drives: Yaris P9 3dr Hatch '08 Join Date: Apr 2014
Will it fit? 7X16'' Offset +20 (car lowered 1.4/1.4)
I'm thinking about putting these BBS on my 08' Yaris 3dr hatch.
Rims: 7X16'' Offset +20 (car lowered 1.4/1.4) They are mounted with 195/45-16 tires. Will the setup fit or will it rub? I have used the calculator on rimsntires.com, and came up with this result: Suspension clearance: 100% clear (leaves even more room than OEM) Fenders clearance: Package 2 will stick out 30 mm (1.2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. Wheelwells clearance: 100% clear (leaves even more room than OEM) SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 57.9mph (93.2km/h): 3.5% slower. Looking forward for some great answers. |
Form>Function
You may have slight rubbing but its nothing a small amount of camber cant fix. I run -1.25 degrees up front and cannot notice any difference in tire wear. I would do it.
īThanks!
![]() I also thought about adjusting the camber a bit but what about the rear tires will ther rub or are there more space in the rear.?
Form>Function
there is usually less space in the rear but 1.4" drop on our cars leaves a pretty large gap back there since we have a lot of rake stock. You probably will have a lot of gap so no rubbing unless on a huge bump or with passengers back there
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 05:19 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 03:57 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 06:02 PM |
| Who makes the best custom fit car cover for our car? | YarisSedan | General Yaris / Vitz Discussion | 8 | 04-30-2009 12:13 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 11:58 PM |
