![]() Drives: Yaris and dc2 Join Date: Apr 2014
Fan not turning on
Help fan not coming on my 99 yaris I put power to fan it works change the thermostat still not working is there any relay or fuses
The 30A RDI fuse feeds power to the fan.
There are two relays: FAN NO.1 Relay and FAN NO 2. Relay. The ECM and the AC ECU both have the ability to make the fan run. If you start the engine and turn the AC on, the fan should immediately start running.
the 30a look ok and my car doesnt have ac so we only have one fan no1 relay i swap the relay with the horn relay not difference
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
coolant
you sure the coolant is hot enough to turn on the fan? put an elm32 obd2 reader on the obd2 plug and use your smart phone to check the coolant temperature. I believe the fan don't turn on until the coolant is up to 195-200F, Your thermostat could be stuck open.
| Wheels slipping when hard lock turning - dealer says this is normal? | eskiepeskie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-08-2012 09:49 PM |
| Fan Not Spinning Up, Random Airbag Light | drannonb | DIY / Maintenance / Service | 12 | 10-23-2012 04:33 PM |
| AC Blower Motor / Fan Does Not Turn on Period | dyslexicanaboko | DIY / Maintenance / Service | 7 | 01-30-2012 11:59 PM |
| Abnormal radiator fan | hi577 | DIY / Maintenance / Service | 0 | 01-21-2012 04:34 AM |
| 2006 Yaris clicking/clunking when turning | heistp | General Yaris / Vitz Discussion | 1 | 10-13-2009 10:48 AM |
