Drives: 2007 Yaris hbk Join Date: Dec 2008
Engine light + loss of throttle control
Just looking for some advice.
Ongoing engine light problem with my '07 Yaris 5 speed hatchback. 313,000km. Engine light coming on every other day, sometimes with nothing noticeable happening , other times the car starts to hold the acceleration on it's own. So I take my foot off the peddle, and the car holds that level of acceleration (no the peddle isn't stuck on a mat). If I push the clutch in, the Rpms slowly increase. I turn off the car , turn it back on, engine light stays but the gas peddle responds normally again. I took it to the dealership and they retrieved the codes: P0011 - camshaft position 'A' timing over advanced, or system performance. (This code started coming on a year ago and was chalked up to the sensor being dirty from a time when I had to leave the car 6 months unused. C1541 - vehicle speed sensor V0105 - Lost communication with fuel injector control module. They said they could not provide a diagnosis, cleared the codes and told me to let them know if it comes on again. Of course just as I was driving home it came on again. Any ideas what could be going on? And why with the codes a diagnosis wouldn't've been able to be made. Thanks! |
With the V0105 code, I would suspect the ECM to be the issue. You might want to remove it and pop the cover on it to see if there is corrosion on the circuit board.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| MAF check engine light and transmission help | heeroyuy01195 | DIY / Maintenance / Service | 22 | 04-03-2012 02:16 PM |
| Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? | zimso | General Yaris / Vitz Discussion | 3 | 10-19-2010 07:17 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
