Old 06-22-2014, 10:54 PM   #1
Iceman6969
Iceman6969's Avatar
Drives: 2010 Yaris Sedan
2010 Yaris Sedan - TROUBLE W/ TROUBLE CODES
So, last year I am turning left at an intersection and as I straighten out of the turn the Yaris dies. After the tow truck got us home, I began looking for the problem. Being the person that I am, the car never got below 1/4 of a tank of gas. BUT, when I went to check the fuel pump (the hard way), I found the tank bone dry. So, I put a couple of gallons of fuel into it, with the outcome of that being negative. Still nothing.
OBD 2 code reader was displaying eight(8) trouble codes. Now after new fuel pump w/New Sub-plate. And Now NEW Mass Air Flow Sensor, four (4) trouble codes.
-P0101 Mass or Volume Air Flow / A circuit range/performance
-P0113 Intake Air Temp Sensor 1 circuit high input
-P0010 Intake (A) Camshaft Position Actuator Circuit / open Bank 1
-P0171 Bank 1 System Too Lean
As I stated, I just put in a NEW Mass Air Flow (MAF) Sensor. When I took the old one out to inspect/clean/reinstall I found that it looked like someone had put it in front of a propane torch.
Is there a procedure for the MAF to re-learn anything? or is it just plug&play? The Camshaft Position Actuator Circuit, is there a way to test this? And Where would the Air Temp Sensor be found?
Iceman6969 is offline   Reply With Quote
Tags
air temp sensor, camshaft position sensor, maf, mass air flow sensor, system too lean
2010 Yaris Sedan Phelms Performance Modifications 7 11-24-2012 01:06 PM
2010 Yaris Sedan tommy2010 Cars for Sale by private party 1 11-23-2012 07:03 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 02:50 AM
