Old 07-29-2014, 11:05 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What does the gear select damper do?
I'm almost done rebuilding my Frankenstein gearbox, and it occurred to me that I don't really understand what the damper on the gear select shaft does. I mean, I can piece together that it dampens something, but is it a NVH reduction device or does it actually do some work when changing gears? The Celica and Matrix gearboxes had them, but they were very different. I.e. one was somewhat-asymmetrical and the other was completely-asymmetrical, whereas the Yaris/xB has an almost-symmetrical damper.
If it's only there to provide resistance at the shifter--increased shift effort--then I may just run without it!
Old 07-29-2014, 11:41 AM   #2
Off of the tranny, what does that big ol' chunk of metal weigh?
Old 07-29-2014, 01:42 PM   #3
CrankyOldMan
Just over 2 lbs.
Old 07-29-2014, 01:45 PM   #4
Originally Posted by CrankyOldMan View Post
Just over 2 lbs.
Ah, not as heavy as I thought. I suspect that its purpose is to dampen vibration through the cable to the shifter, and possibly to assist with shifting as the momentum of it would help with fully engaging a position. The shape is probably just based on what's around it once the tranny is mounted in the engine bay.
Old 07-29-2014, 03:04 PM   #5
CrankyOldMan
That's what I was thinking, but it helps to have someone else articulate it. I'm not worried about NVH, but there's the issue of dust protection for that end of the shifter: the bellows isn't sealed by the damper, but it looks like it keeps it in place (more or less).
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
