![]() Drives: 07 Yaris hatchback Join Date: Aug 2021
rear end howl. sounds like a bad bearing, but it isn't
I'm trying to diagnose an issue that I have been dealing with for a while now. I drive an 07 Yaris which emits a loud howling noise from the left rear tire. This noise becomes noticeable around 40 mph, and gets louder as the vehicle speed increases. When I turn the wheel to the right, the noise will go away, but when I turn it to the left it becomes worse. I suspected the bearings were bad, so I put new ones in, but that did not lead to any improvements. I replaced the tires, coil springs and shocks, but still no luck. I'm now suspecting an alignment issue, but I have read that these cars can only be adjusted with shims. I have the printout from my most recent alignment which was done when the noise was still a problem. The left rear lists -1 camber and .11 toe. the right is -.8 camber and .2 for the toe. does this seem far enough out of spec that it would cause this type of problem? I'm at a loss. any help would be appreciated.
How are the front tires and the bearings in the front of the car? The fact that it makes noise when you turn the wheels Might indicate that
Good luck and tell us what happens!
#3 | |
Drives: 2009 Toyota Yaris Join Date: Oct 2021
Thanks, in advance, for any help/advice! |
![]() Drives: 2007 Toyota Yaris 5 Dr HB Join Date: Oct 2021
Have you check the metal heat shield just above the muffler? Mine had a grinding howling sound and the screws rusted right out making the heat shield loose. I removed the heat shield completely and no more sound.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
My rims are dented so bad or so out of round that they make noise
| Tags |
| alignment, noise, rear end, tire |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Creaking sound from the rear end after stops bumps, turns after it rained | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 03-06-2009 01:57 PM |
| Groaning, creaking, from the rear end after taking off from stop and sometimes turnin | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-06-2008 12:31 AM |
| Noise coming from rear end! | tfman716 | General Yaris / Vitz Discussion | 15 | 10-28-2008 01:37 PM |
