![]() Drives: Yaris 5dr hatchback 2nd gen Join Date: Jun 2013
2SZ-FE custom air intake check engine light
in the second pic it looks like the sensor is sitting sideways so air flow maybe not direct.
Thanks , the sensor is the same position as it was on the stock air filter box
Also, the diameter of the pipe needs to be the same as the OEM. If the diameter is larger, it affects the airflow value the sensor is picking up. I can't tell in the picture, but if the relocation of the sensor doesn't work, it may be the diameter of the pipe
Hmmm never had that problem could be ...my intake is larger than stock made out of 3 I had around lol
sent from my S4 on Mars |
Just had a look at the original position of the MAF on the stock air box and its downwards compared to the pic above. May be the issue but if that doesnt work, any other suggestions?
Thanks for suggestions so far guys! |
2ZR swap. DO IT! Ask how!
What is the diagnostics code? It's much easier to pinpoint with those than just a general "check engine" light.
Sorry mate, how do u get the code?
Sent from my iPhone using Tapatalk |
I'm not sure if there are car parts stores in the UK, but over here in the colonies we have stores that will read the codes with an OBD II scan tool for free. If not, a repair garage should be able to.
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Check Engine Light on at 32k kilometers? | caper26 | DIY / Maintenance / Service | 21 | 10-16-2013 12:27 PM |
| check engine light - reading codes? | delbo21 | DIY / Maintenance / Service | 3 | 09-02-2011 05:48 AM |
| Check Engine Light Question | falkor_99 | General Yaris / Vitz Discussion | 11 | 07-22-2007 05:15 PM |
