![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
Car occassionally makes brief squealing noise at startup...
Didn't start until I had the belt replaced about 25k miles ago. Happens in any weather... had one shop install it and squeal started. They told me sometimes it's caused by the belt stretching after new install or something of that nature. They tightened it and the noise went away for a while.
Started doing it again more recently so I had another shop look at it. They said it does it for like an instant at startup but they didn't hear anything else past that and I guess there wasn't anything they could do to fix it? ![]() The second shop did suggest it might be a pully going bad? I guess the pulley's have bearings??? Anybody? |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
The belt has loosened again. Just retighten it
What brand of belt is it? Some of the stiffer composition belts (like Dayco) are prone to that behavior.
I'm not 100% sure - but I will inquire when I'm in for my next service. The other shop I went to couldn't find any issues with the car at all so I'm guessing it's likely what you're describing...
I ran into this with my red Yaris, when I installed a Dayco belt. I tightened it about half a dozen times before I threw it in the trash and installed a Gates.
I'm pretty sure it's the belt as well. Mine was just about to explode when I finally figured out where the sound came from.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Ive had this for a long time. I figured it was the aluminum MI pulley. I think the belt I installed was a Dayco...ill check when I get a moment
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
dayco ,
Correct it's the Dayco cheapo belt I have the same belt and same minor issue. Get the gates or the OEM Toyota.
![]() Drives: No longer own a Yaris Join Date: Jul 2014
Belt squeel can be from a belt not tight enough, too tight, warn belt, a crappy new one or crooked warn pullys.
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| What Car Mechanics Don't Want You to Know!! | daddz07 | DIY / Maintenance / Service | 16 | 04-17-2011 10:10 PM |
| car making cheap car noise | the_boss | Cosmetic Modifications (Exterior/Interior) | 5 | 03-07-2011 08:05 AM |
| Who makes the best custom fit car cover for our car? | YarisSedan | General Yaris / Vitz Discussion | 8 | 04-29-2009 11:13 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
