![]() ![]() Drives: yaris hatch is the sh*t Join Date: Jan 2013
15x8+25 lowered on tein 2" lowering springs
hey guys, i have a question about some rims im thinking about getting. im lowered 2 inches with tein lowering springs and im looking to swap my wheels out with some 15x8+25 wrapped in 185/45/15's...is there going to be any problem with rubbing? do i need to roll/pull my fenders? let me know. thanks guys!
I run Monarch Nilo's 16x7 front 3 inch lip, 16x8 rear 5 inch lip +20 all around offset.
http://www.yarisworld.com/forums/sho...light=Nilo%27s If you do 15x8 on the fronts they will stick out a lot more than the rears compared to the placement of the front fenders vs the rear fender. To answer your question, yes, on hard dips your back and front wheels will hit the fender possibly. Rolling will help a little but not always and most likely not on the front at all. Last edited by KCALB SIRAY; 08-18-2014 at 04:04 PM. |
thanks buddy, im going to probably run 15x8+25 and see how it goes, if it doesnt work ill throw my old rims back on. thanks for the help.
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
I'm running 15x8 +20 in the front. Rolled, no pull and -3 camber. Clears fine with 195/50's.
Edit: But I did have to shave down the section on the fender that holds the bumper clip significantly.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
Meagan coilovers, with 6 inch 9k springs in front and 4 inch 7k in the rear. Usually keep my dampening around 3/4 stiff unless I have people in the car.
![]() ![]() ![]() Drives: Toyota Yaris 2009; 1.0 3 Cil. Join Date: Oct 2010
Im going to run the same measurements, except my tyres are going to be 195... I expect some rub... probably going to roll the fenders a bit.
Speedbumps suck...!
i was going to run 195's also but i figured if i can get my hands on 185's then im going to so i can stretch it a little to make the rubbing a little less of a problem. what tires do you plan on running?
Falken 195/45/15... I also wanted 185 on the new wheels... but then I have to get Nangkang or other crap tyres... but I really wanted some good falkens so I can drive safely in the rain (which is a bitch on nangkangs). And Falken doesn't have 185/45/15
Speedbumps suck...!
With a 195, I did have to do some good cutting/grinding on the front and back. I can get a pic of what I mean if you want me to (might be a few days)
Also should add that my coilovers have me at close to a 3.5-4" drop from stock. Sub frame is sitting 2" off the ground at all times. I don't think you're going this low.
#12 | |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
those wheels should fit fine with just lowering springs. I would think you'd have to be driving excessively hard to make that setup rub. I am slammed on coils and I had 195 50's on 15x8 et 25 and I barely rubbed.
| FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks | Freestylin | Items for Sale by private party | 21 | 02-04-2014 07:33 PM |
| TEIN S.Tech lowering springs - experiences? | Ot_tO | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 02-24-2013 05:58 PM |
| FS: Tein S-Techs Lowering Springs | YAR1S | Items for Sale by private party | 18 | 01-13-2012 11:03 PM |
| Tein lowering springs don't fit... | CrzyCrg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 01-12-2011 11:27 AM |
