Old 03-26-2014, 12:59 AM   #1
end user
GRO H2O
Drives: Yaris
Mini Cooper rims question
I'm looking to get the wheels shown below if I can get them cheap enough.Question is do I need hub centric rings for them and what kind of lug nuts do I need if differant than stock steel wheel ones.
Dunlop SP Sport run flat tires (205 45 R17)
end user is offline   Reply With Quote
Old 03-26-2014, 06:36 AM   #2
Look at this post for info:
http://www.yarisworld.com/forums/sho...&postcount=505
Old 03-26-2014, 06:51 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've been running R81 Immola wheels in the summer for the last year or so without rings and have no issues to report. I use the Gorilla style spline nuts that came with my TireRack wheels as well. CTScott probably has the best solution for avoiding possible problems, though.
Old 03-26-2014, 08:18 AM   #4
LTHatch
Drives: 2013 Yaris Hatchback L
Running R81 mini wheels as well with the lug nuts that CTScott linked, 60+ vibration was very noticeable and at 75+ it felt like a jackhammer. After installing the 56.1->54.1 hub rings, its smooth sailing up to 100mph at least.
LTHatch is offline   Reply With Quote
Old 03-26-2014, 11:35 AM   #5
end user
GRO H2O
Drives: Yaris
Wish I could find the Running R81 locally but not much available and people want liek $800-1000 LOL for factory rims.
Old 03-26-2014, 05:27 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Is this what you're looking for?
http://inlandempire.craigslist.org/pts/4392168984.html
Old 03-26-2014, 10:40 PM   #7
CrankyOldMan
Those are indeed Imolas. Mine are white, with a splash of brake fluid that chewed through the paint. The real secret is that they're only about 11 lbs.
Old 03-26-2014, 11:48 PM   #8
end user
GRO H2O
Drives: Yaris
Yah those are pretty awesome.
Old 03-27-2014, 12:06 AM   #9
kimona
kimona's Avatar
^Imolas are often available here on craigslist for about $200.
Old 03-27-2014, 01:14 AM   #10
end user
GRO H2O
Drives: Yaris
Unfortunatelly California has more people than Canda put together :P You hosers get the bigger selection and cheaper prices although our weed is better and cheaper This is my local selection lol http://vancouver.en.craigslist.ca/se...axAsk=&excats=
Old 05-04-2014, 02:18 PM   #11
3rdSEman
3rdSEman's Avatar
Drives: Black 2012 SE manual
centering rings
I would suggest everybody to not bother ordering centering rings.
http://www.hubcentric-rings.com/
56.1-54.1 rings are fragile and break easily (shatter) when fitting wheels.
I have ran different mini wheels so far and have relied on centering feature of standard taper nuts.
One word of caution if you're considering extended tip conical wheel nuts. I believe available tips (extending below the taper) are mostly imperial. Never could find one which would fit (and center) metric bore openings of mini wheels. Thus my use of plain standard taper nuts.
PS: tires fitted are Michelin Pilot Sport A/S 3, 500 treadwear, asymetric tread pattern, side-to-side rotation is allowed as they are not directional (permits rotation in a criss-cross fashion).
PS2: true winter tires are a must (and mandatory) in Quebec; these A/S tires are only used during other three seasons.
3rdSEman is offline   Reply With Quote
Old 05-07-2014, 07:44 PM   #12
scmoky
Drives: Yaris 2012
So what dimensions are these Mini rims(15 with 4x100 bolts? what about ET)? And if it fit to yaris Mk3 gen. without any rear and front spacers and if can use standard bolts? In my country I can get it cheap.
scmoky is offline   Reply With Quote
Old 05-04-2014, 04:12 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
this is the mini wheel i would love to run on my Yaris ....think they are 15s
if anyone does please post pics or the one below in white too
Old 05-19-2014, 10:41 PM   #14
end user
GRO H2O
Drives: Yaris
Attachment 53447
I picked up a set ($440 CDN) of these in silver with pretty much brand new tires on them but they are 175 65 R15 will do for now I guess. Since my Yaris is the nasty Pacific Blue (its the only color that was available at the time in two door after the Japan tsunami other wise had to wait a long ass time for different colors :P) I'll probably paint them white or gold.
Old 05-08-2014, 08:58 PM   #15
ivanstepul
Drives: 08 hatchback
Stock lug nuts with no spacers. Rides good no vibrations.
ivanstepul is offline   Reply With Quote
Old 05-08-2014, 10:57 PM   #16
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
THIS
that's it. saw a set of these on craigslist for $160. I'm on the hunt very soon.... look so good. gonna plasti dip them black, over course!
trunkout is offline   Reply With Quote
Old 05-08-2014, 11:05 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
like that ...do u have pics of whole car with wheels on .
Old 05-09-2014, 12:24 AM   #18
Stock lug nuts work, but I would not want to run them for very long. Mini lugbolts (shown below) are 14mm (versus our 12 mm lugs), so there is quite a bit of slop to the holes, which results in a significant portion of our OEM lugnut taper sitting in the hole.
The lugnuts which I referred to in the link in post #2 above are shown below. They have a much larger tapered section than our stock lugnuts and the "bulge" fills the 14mm to 12mm gap. They were difficult to find since, as mentioned above, most conical bulge lugnuts are not metric.
Question about these rims. Bar_Red_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-09-2011 08:54 PM
My 17" alloy rims and Kumho tires... will swap for your original wheels! AutoWashCars NY / NJ/ CT / PA 5 02-08-2011 07:38 PM
RIMS a Noob-toob question =] donchae Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 10-17-2010 06:11 PM
Question about Rims MrJester Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-06-2007 10:16 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
