Old 10-30-2014, 05:41 AM   #1
dobrik
Drives: Yaris 2013 1.33 CVT
1.33 engine strange tapping on idle
Hi,
Since the car (yaris 2012, european, 1.33 CVT) was taken from dealer there was strange irregular tapping sound on idle when engine is fully warmed up (~20 min drive). I've pointed out to dealer on first service and have got the answer that it was regular vvti sound, the same said regional Toyota representative. Oil was tried from 0-20 to 10-30 tapping was always there. Here is the recording I've made today in the parking lot after 1 hour drive https://www.youtube.com/watch?v=lpXm6DqkKwk
The tapping is irregular, high sound, when you hear it once you can't unhear it :). At the dealer's they say that I shouldn't worry as engine is under warranty, but still I want too get to the bottom of this, any opinions?
BTW, I've heard the other cars from the same period - some got the same tapping and some not.
dobrik is offline   Reply With Quote
Old 10-30-2014, 08:17 AM   #2
nortonfb
Drives: 2007
Even with my lousy hearing it was apparent.
The tapping remained constant which would rule out the valve train.
I'm stumped.
Maybe Scott will have a good guess.
Norton
nortonfb is offline   Reply With Quote
Old 10-30-2014, 09:42 AM   #3
I would consider the sound in the video to be pretty normal, particularly for the 1.33L, which to me is a bit more ticky than the 1.5L.
Old 10-30-2014, 09:45 AM   #4
dobrik
Thanks Scott, what about irregular tap-tap....tap-tap-tap-tap...tap-tap-tap-tap-tap-tap...and so on (cleary heard from 15s)?
Old 10-30-2014, 11:06 AM   #5
Even that sounds normal. If anything there might be a slight exhaust leak from the gasket between the exhaust manifold and the mid pipe.
Old 10-31-2014, 07:26 AM   #6
dobrik
CTScott you know you're right, finally I was able to pinpoint where the tapping comes from, exhaust manifold, under the heat shield, that's why it's very clear could be heard from the passenger side wheel arch. Actually the same tapping but very weak i can hear from my rav4, so I guess it some kind of toyota's feature. Reminds me my friend's 2003 corolla that had sounds from intake manifold....
Old 10-30-2014, 06:06 PM   #7
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Sounds just like my 1.3
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 10-30-2014, 08:24 PM   #8
3rdSEman
3rdSEman's Avatar
Drives: Black 2012 SE manual
Hey Dobrik,
Your 2012 1.33 1NR-FE engine happily tap-tapping brought back found memories in my mind. Go check following thread + the three links on post# 10 (mine).
Your concern is hard to pick up for an unexercised ear; I can clearly hear it on/and/off on the background. I was a former iQ owner and got rid of the car after being completely exhausted fighting this over with Toyota. There was a fair share of these 2012 engines badly bored or whatever. Some would tap "cold", some would tap all the time (even hot like yours), some this, some that... exhausting !!! there were different outcomes to the problem depending on severity and local laws: indifference from Toyota, short block replacement, car buy back under lemon law... etc, etc... exhausting !!! I wish you good luck. Hey ! I was also told: don't worry your drivetrain is warrantied 5yrs/60,000kms : \
http://www.yarisworld.com/forums/sho...ferrerid=37958
3rdSEman is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Really Bad Engine Sludge... monchito18 DIY / Maintenance / Service 27 05-14-2014 11:47 AM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
