![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1zz tb idle control (allen wrench)
idle stays high between 900-1000 when i drive around town...after 20 second it calms down to 750-800...everybody said chip away the epoxy and turn counter clock wise to slow the idle..felt like it wasnt calming down...so i rotated clock wise and feels like its still the same..i mean it goes down to 650rpm but still takes time...now my allen wrench fu*ked up the screw part where i cannot even spin it anymore..fml 😂😂😂😂😂
tapatalk_1489492059183.jpeg Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
it's not that bad. you will need to drill it out and tap with a new bolt if you still need adjustments. should take 30 minutes if you have a drill and a tap and die set. maybe a left-handed drill bit or remover.
I found it was easer to adjust the idle speed when the engine was cold. I had mine idling at like 500, but it caused a CEL, so I bumped it up a 1/4 turn at a time until it stopped setting code. |
I had mine down to about 650, anything lower and I found it was rough at idle and not "comfortable" at that rpm. It still took 20 or so seconds for it to go down to that rpm on a warm start. That's just part of having the 1zz TB, it's not a problem just a difference relative to the stock TB
2ZR swap. DO IT! Ask how!
If you have any leaks, you'll never get it dialed in right. Don't ask how I know.
I ended up replacing my adjustment screw with a 1/4-20 cap screw, and it "mostly" worked.
| What size allen wrench for auto transmission drain bolt? | detroiter | DIY / Maintenance / Service | 6 | 03-30-2019 02:55 PM |
| Engine Control Module Code and Rough Idle | rks171 | DIY / Maintenance / Service | 4 | 05-13-2015 10:47 PM |
| I NEED Boost... Opinions puh-lease | Focus_Sh1ft | Forced Induction Forum | 551 | 02-08-2013 05:55 PM |
| I need Help on Idle Control | Parmas | DIY / Maintenance / Service | 5 | 08-11-2010 09:35 AM |
