![]() Drives: 2007 Yaris sedan Join Date: Apr 2013
NF210 Tanabe install
Thanks to Chris07LB for his guide. I bought these springs used from Fenanorn a couple weeks ago and finally had a chance to put them on.
Just wanted to put a little info on the install and some pictures. car is a 2007 automatic, 84k miles and pretty much stock. this was my wifes car which i now inherited after i sold my gt500 a few months ago, so now this is my daily driver. The hardest part of the install was on the front end links, there is a spot for a 6mm allen key inside the bolt, my endlinks were corroded and rusted. Couldn't for the life of me get them to turn, so i picked up a 6mm allen socket and messed both links up. So i was over thinking it and tried drilling one side out, as i thought it was a cap screw originally. Put a set of vice grips on the back and hit it with my impact and came off instantly. Couldn't believe i wasted so much time on this part. The instructions said cut from 18mm to 25mm off the bumpstop, 25mm equates to almost an inch, which is pretty much what i cut off on both sides. I didn't follow Chris' info on this, and i hopefully cut the right part according to tanabes instructions. The rear springs are very easy, and the front is not too bad with air tools. I removed the wiper motor and underneath brackets so i could just hit the top strut nut with the impact. After i finished it, i saw my strut mounts sit up some, but i never noticed if it was like this with the stock springs. car drives much better and sits better as well. going to be putting on some mr2 spyder rims on soon and i'd like a rear sway bar. no real big plans past that. the yaris is a good economy car and has served us well for 60k+ miles. i am quite happy with it. |
more pictures
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Springs really help the handling. Have you added a rear anti-sway bar yet? If not, do! Amazing the difference!
Excellent choice on springs. I've had the same ones for years over stock shocks and they refuse to die.
Did Yoda hack into your account again?
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() Drives: 07 Yaris Liftback Join Date: Oct 2012
Stock Shocks
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
No you don't need to replace shocks. NFs are such a mild drop that really do not negatively impact the stock shocks/struts.
Not yet, id like to get the 23mm one though. Probably going to be the next thing i do.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
wait until the springs settle...and once you add in a 23mm sway bar, you'll be blown away by what something so simple can do.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
yes, but once that is done you will want a little more and go for the front sway bar... amazing difference i dud its
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
I have a front sway bar on it, not sure what the size is though.
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
Thicker front swaybar will contribute more understeer though. I like stiff rear, loose front, lets you kick the tail out.
![]() Drives: 2012 Yaris Join Date: Apr 2013
Congrats on being dropped! About how much time did the install take?
#13 | |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
NF210s are great. I love mine. Also, definitely add the sway bar, it makes a HUGE difference in the body roll.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#14 |
this works too:
#15 | |
When you reduce roll, part of what happens is an increase in the contact patch in front.
#16 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I out the 23mm bar on the back of mine and at was ridiculous how easy it was to step the tailout with some trailbraking. Put on the 25mm front bar and that helped settle things down...but at the cost of low grip low speed push.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#17 |
Sorry for the lack of update, my install took about 4-5 hours.
Here is an updated pic with my mr2 rims. ![]() gif upload |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Another Tanabe Medallion Exhaust Install | CharlieBravo | Performance Modifications | 20 | 02-18-2013 01:54 PM |
| Tanabe NF210 Springs | Shinare | Items for Sale by private party | 12 | 12-06-2011 04:42 PM |
| Tanabe NF210 spring install help | Jerkratt | Performance Modifications | 8 | 06-08-2007 11:13 AM |
| Tanabe DF & Strutbar install | mcdaddy | DIY / Maintenance / Service | 18 | 05-03-2007 10:57 PM |
