Old 01-04-2015, 05:35 PM   #1
Eduardo_mty
DRL fuse..
I saw the right fuse box on the motor compartiment...
If i install the right fuse (7.5amp) can i use the DRL system?
Wich cables i need to tap ...
See picture
Eduardo_mty is offline   Reply With Quote
Old 01-04-2015, 06:59 PM   #2
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Um, no?
I assume only one of the fuse holder's side has contacts :D
Retrofitting things that go deep like this into the wiring is a pain in the ass.
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 01-04-2015, 08:54 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
The DRL relay goes on the left of the radio. If your car didn't come with it, it appears that you cannot just buy the relay to plug it in.
help re wiring fuse box please kommodore DIY / Maintenance / Service 1 04-01-2014 03:11 PM
power outlet/cigarette lighter fuse location Idahotom General Yaris / Vitz Discussion 1 01-08-2014 06:45 PM
Blown or missing gauge fuse causes strange symptoms on a 2007 Yaris hatchback vandallen DIY / Maintenance / Service 1 06-06-2013 10:59 PM
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 07:53 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 11:59 PM
