![]() Drives: Yaris Join Date: Sep 2012
2014 Yaris LE radio replacement help needed...
I have the Toyota PT546-52121 in my Yaris and I would like to replace it with my trusty Blaupunkt Long Beach that I had in my 2002 Echo. I have found a Single DIN to Double DIN adapter but I need some help regarding the rear panel pin out on the PT546-52121 as well as what sort of adapters I will require to connect the harnesses in my Yaris to it. I am aware that I will lose the USB and Aux. input features (not that I will miss them since some genius in design stuck them in the glovebox!) as well as Bluetooth connectivity, and the steering wheel controls. I don't care about that I just want to get the Blaupunkt going again.
Here's a link to some more detailed information about the Long Beach-- http://www.sonicelectronix.com/item_...ach-DVD35.html I'm hoping someone can get me started on this. If you need more information please ask. Many thanks! |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
the pinout is pretty standard with the Toyotas. if you have USB, aux in your blaupunkt, you can even make them work.
you may want to buy those toyota harness adapters from ebay or amazon (i think) so you won't have to do any wire splicing/cutting. http://www.microimageonline.com/foru...32-YARIS-FILES |
^Exactly - You just need one of the radio harness adapters (Like the Metra 70-1761) and the antenna adapter harness (Like the Metra 40-LX11).
The Metra harness comes labeled with the wire functions, so you click it onto the OEM harness connectors and them crimp or solder the wires to their appropriate functions on hour head-unit's harness.
#4 | |
When it comes to removing the dashboard panels, what is the best way to go about doing it without damaging anything?
#6 | |
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
![]() My audio system is a Kenwood double-din and I only needed to remove (3) and (5), the dealer used a Metra adapter that connects to the car harness. And don´t forget disconect the negative (-) pole of the battery. |
Thanks to everyone that took the time to post in this thread. I truly appreciate the suggestions and I finally got around to putting my Blaupunkt in the Yaris today.
I have a couple of questions. I used the following antenna adapter-- http://www.amazon.com/Metra-40-LX11-...=Metra+40-LX11 ---on the antenna. I didn't connect the blue wire to anything as I didn't see anything to join it to. However, I am unable to pick up any AM radio stations. Is there something I should have done with that blue wire? The antenna on my Echo was a lot longer than the one on my Yaris and I am wondering if this is affecting my radio reception. Anyone have any thoughts on this? |
The blue wire of the Metra antenna adapter needs to be connected into the blue wire of the headunit harness (Power Antenna).
![]() The the antenna uses an amplifier when the radio signal is weak or have interference, noise, etc. |
Yes I heard back from Metra and they said the same thing. I will check and report back. Thanks joell!
joell just to be certain, you are talking about the blue wire that comes straight out (not the one that curves back) of the Metra 70-1761 harness correct?
joell another question. Are the red and black wires in the harness the 12+ and 12- wires? I'm thinking of connecting a small LCD monitor so that I can navigate the menus on my DVD-Audio discs.
If you look at the image of post #8 I tapped +12V (red) and ground (black) for the reverse camera. I think it depends of the size of the screen, a small monitor will not consume too much power.
| 2014 Yaris SE or Corolla S? | buda | Third Gen Yaris General Discussion | 62 | 06-16-2014 03:06 AM |
| Toyota Yaris 2014 license lights replacement | Alexr | DIY / Maintenance / Service | 2 | 02-03-2014 05:19 PM |
