uk hardcore for life
Drives: toyota yaris 2008 sedan Join Date: Jul 2010
water pump
Hi Guy, since yesterday my yaris do the noise from the water pump without any leak, i want to know if i can run the car 10 or 12 day before i got the new pump or i need to park completly the car, i do 25 km by day.
Thanks |
Anything can happen. Watch for leaks and overheating. Unfortunately our cars don't have an engine temperature gauge, just an idiot light, so I would be less likely to take a risk.
A car with a completely broken waterpump can overheat within 2 km. All that being said, I drove a car with a damaged (but not broken) waterpump for a few weeks without any problems. However, if it decided to give up in the middle of any of those drives, I would have been stranded and needed a tow back. |
![]() ![]() Drives: Want a yaris Join Date: May 2012
You're in Canada and it's winter. You should be ok for a couple days. You will need to worry about that bearing shearing and sending parts throughout your cooling system though.
Have you loosened the belt to see if the noise stops? |
Probably you will be OK.
If it was my car I would drive it. But have a plan in case something bad happens! Good luck!
Be careful, the water pump impeller might be grinding on the housing inside.
Hi Thanks for your help, finally i have find a new aftermarket pump and i will install tomorrow. I have send the car to a garage and is only the pump, i will talk to the mecano if he see some grinding in the housing.
cautious
You can drive it but watch for leaks/puddles under the car every time you park it because they have a weeping hole and when that starts to leak...well brother you better change it out ASAP or you'll find yourself stranded.
The Martian
I hate that temp light.
When the water pump fails no coolant is pushed past that sensor so it just reads the temperature on the outbound coolant line which stays cool and will read hot when you take a corner that moves the hot coolant to the sensor. So essentially if it fails the only way you can know is if you have the heat on and it starts blowing cold.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
![]() Drives: 2010 Yaris 4-door Sedan Join Date: Sep 2014
Just replaced my Water Pump. Sounded like Marbles in the engine.
One week I took my car in for Oil Change and Tire Rotation. Two weeks later the Water Pump started making the noise. Of course I thought they did it, lol. Next my brakes started feeling like a sponge. I drive a lot, but come on. lol. |
| water pump change 2sz-fe | finnpoulsen | DIY / Maintenance / Service | 5 | 03-25-2020 10:20 AM |
| Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 08:05 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| HELP: changing water pump | dlplunkett44 | DIY / Maintenance / Service | 4 | 02-06-2011 09:26 AM |
