Old 05-16-2022, 12:29 AM   #1
TiedBassDrummer
Drives: 08 Yaris 3dr
Question Am I taking the transmission out again?
I recently replaced the clutch for my Yaris. Along with the flywheel and pressure plate. Before I started bolting more things back together I figured I should test to make sure that neutral was neutral, and discovered what is seen in the video.
https://youtube.com/shorts/LyJIz_jwhSs
At 8 seconds I press the clutch pedal in.
At 13 seconds I release the pedal.
I am 95% sure this means I need to take the transmission out again, but I would like someone more knowledgeable than I am, cause I'm sure not, to weigh in.
TiedBassDrummer is offline   Reply With Quote
Old 05-16-2022, 08:14 AM   #2
ex-x-fire
No, that's normal when the tranny fluid is cold. For some reason the spinning main shaft cause the fluid to whip up and make the other shaft turn a bit. Put the wheels on and you'll see that you can stop it easily by hand.
Old 05-16-2022, 01:57 PM   #3
TiedBassDrummer
Thank you ex-x-fire. I did notice that it was easy to stop by hand when I had a tire on.
remcafee - I did not install a lightened flywheel. I put an OE flywheel in. I know I have come across old posts about lightened flywheels on the forum though.
Old 05-16-2022, 12:27 PM   #4
remcafee
did you install a lightened flywheel? im thinking about doing one and trying to seenif anyone here had one so i can get some input
Old 05-16-2022, 08:15 PM   #5
ex-x-fire
If it's a daily driver I wouldn't use a light flywheel.
About to replace the transmission fluid on an automatic 2008 yaris with 172kms jessesYaris General Yaris / Vitz Discussion 6 09-23-2021 05:51 PM
Transmission heating up ? David C DIY / Maintenance / Service 9 08-04-2016 02:25 PM
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 11:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
